Question about HP Office Equipment & Supplies
Incorrect yellow error hp 2820 - HP Office Equipment & Supplies
5 Suggested Answers
Patrillica
  • 141 Answers
SOURCE: HP laserjet 2820
Does it work with this error....if so you wanna
make sure that you have a HP cartridge, sometime the chipset is not recongnize....and you have some function that doesn't work. If you try all this, call HP.
Posted on Mar 26, 2008
Nandakishore
  • 304 Answers
SOURCE: HP Laserjet 2820
Replace Yellow Cartridge or its Drum.
Posted on Sep 18, 2009
  • 313 Answers
SOURCE: my hp color laserjet 1600 ''incorrect yellow''
did you use a genuine toner cart.........!!!!
Posted on Mar 31, 2010
seeker5211
  • 1089 Answers
SOURCE: clear error code on hp 2820
Could be scanner assembly or formatter
Posted on May 18, 2010
Hp color laserjet 1025 cartridge memory error on imaging drum
If the ground spring located on the left inside wall of the printer is ok, and you have tried cleaning all the ground contacts on the cartridge, then it may just be a bad toner cartridge. Especially if it's a third party cartridge and/or especially if this problem happened right after or shortly after installing a new cartridge.
Jan 19, 2015 | HP RB3-1025 Hewlett-Packard Color Laserjet...
Incorrect Yellow
Are U installed specified yellow cartridge? Chk with old cartridge & chk for the message.. Same error? there is a mechanical issue, carousel unit might be misaligned..To align it technical skills required, better go to the nearest service center.
If different error replace with another cartridge.
Feb 22, 2014 | HP LaserJet 2840 Printer
Supply error 10.1004 on HP laserjet 2820 printer
this error comes when the printer not reco the cairtages & drum if u replaced the print cairtages then replace the drum & calibrate the printer & restore the factory default.
May 12, 2010 | HP LaserJet 2820 Printer
Hp clj 2820/2840 alle-one printer. print yellow page oly
we had one in our company for 3 years.....once it starts acting wacky its time for it to go. an hp repairman told us it was the main motherboard inside. it would have cost us 350. we just bought a new printer different series instead.
Mar 01, 2010 | HP - PRINTERS - CLJ 2820 AIO 20/4PPM 96MB...
HP Laserjet 2820
Sep 18, 2009 | HP LaserJet 2820 Printer
HP LaserJet 2820
Push the button to align another color and open the door and take notes on where the carousel should be when changing a toner, Not sure why it would bypass yellow altogether but may be resolved by manually changing out the yellow. When you open the door to the toner compartment there should be something on the door that depresses something in the machine which will unlock the carousel and allow you to turn it by hand when you depress the same lever with some type of tool that will fit in the slot. Rotate the carosel until the yellow is where it should be when replaceing it then let go of the locking mechanism and replace the yellow toner. hopefully between changing the toner out and powering the machine off/on will get you back in business... Hope this helps you out and if it does please list as a fixya... if not, you may need to upgrade the firmware and that's not to hard if your on the network already...
Sep 24, 2008 | HP LaserJet 2820 Printer
Wrong Yellow
Did you get the correct yellow toner? It's possible that the tabs which identify the cartridge are misaligned or broken. Try a new one.
Sep 22, 2008 | HP LaserJet 2820 Printer
Clear error code on hp 2820
Jun 24, 2008 | HP Color LaserJet 2600n Printer
HP Laserjet 2820 getting error 10.1004 supply error when installing a new imaging drum. Anyone ever got this error msg? Thanks
Mar 26, 2008 | HP LaserJet 2820 Printer
HP LJ 2840 problem
I'm about to dive into the printer and change the carousel. I'm having the same incorect yellow msg even when the cartridge is not inserted... I'll be back with further info.
Feb 12, 2008 | HP LaserJet 2840 All-In-One Printer
217 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
