Question about Delta Saws
Delta Side Kick table saw will not start,
Delta Side Kick table saw will not start, worked fine yesterday
  • 4,234 Answers
If there is no response at all, check the circuit breaker on the motor. There is a heat triggered breaker there. That is the most common cause of this. If that is not the case, please update this and we'll look further.
Dan
Posted on Feb 04, 2010
I own a Delta Shopsmart table saw model TS220LS and I have not used it for years and it still work but I don't know how to get the saw to rise above the table level. thanks.
On pos 75 page A turn the depth adjustment clockwise otherwise if its blocked by wood or other trash control the mechanic and clean it dry .
  • Delta TS220LS TYPE 1 Bench Table Saw Parts
Sep 17, 2016 | Delta Saws
Need an owners manualfor a Delta 36-750 table saw
Delta Machinery has two 36-750 saws on their support site; please check the label to determine if your saw is T1 or T2. If you start here: http://www.deltamachineryparts.com/ , you can look up the model number for most Delta tools. The link to the instruction manual will be on the right side of the specific product parts page, below links for various parts diagrams.
The two saws use the same instruction manual. The direct link to the manual is http://www.deltamachineryparts.com/documents/instruction_manuals/En422-35-651-0011.pdf . (Note: this manual also is for the 36-755.)
I hope this helps.
Dec 03, 2015 | Saws
My saw was working fine yesterday, and today it will not turn on. the motor wont even kick a lttle, i flip the on switch and nothing.
with a volt meter See if you are getting 110 volts to the switch and then see if your getting ower from the switch to motor.
Mar 17, 2011 | Makita 2704X1 Electric Table Saws
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
The motor on my delta 10" table saw starts a low rpm and does not go into high rpm - after a a few seconds it fails the circuit breaker, and without the belt conected this does not happen. Is the motor...
This saw tends to have a problem where the belt rides "outside" the V-grove. Check that the belt is actually installed into the V-grove, and that the grove is in line. Mine was installed (at the factory) with the shiv back to front, so the belt would catch, and kick out. Maybe the same issue.
Jan 30, 2010 | Delta 36-716B 10" 1-3/4 HP 120/240V...
My delta 36-650 table saw 1.5hp motor dims lights
If you didnt replace your switch ... do so now. If you did replace the switch, check your work
Oct 25, 2009 | Saws
Delta table saw motor trips breaker
The motor needs a new start capacitor.
Apr 09, 2009 | Saws
Saws Logo
136 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
