Question about RIM BlackBerry Pearl 8100
Coleman Powermate Generator 4600 series
Starts Generating 120 volts and within 20 seconds is putting out 58 to 60 volts. Have changed both diodes or rectifiers. Can turn it off let sit 5 min and it does the same thing.
Starts Generating 120 volts and whitin 30 seconds is putting out 0 volts, and the generator has high speed
Posted on Aug 19, 2008
Only has 120 volts,can not get 240volts
the generator consists of 2 120volt windings that run in parallel for 120 volts and in series for 240, check the change over switch make sure a wire hasn't fallen off, if you have a multi meter check both coils have the same resistance
Jul 19, 2014 | Coleman Powermate Powermate 5000W...
High voltage?
Make sure the engine RPMS are correct, and change the capacitor in the end of the alternator cover
Jul 24, 2013 | Coleman Powermate Powermate 5000W...
I have a PMC543250 Powermate generator. It just
check
avr / brushes if it has them
if not capacitor and diodes on the end of the armature
Feb 16, 2010 | Coleman Powermate Powermate 5000W...
I have a coleman powermate 6250-5000 running watts-generator. The generator starts and runs but does not produce current to outlets,the outlets are fine-they have continunity,I removrd the armature and...
You may have just lost residual magnetism in your rotor. Start genset then apply 12 vdc to 120 v outlet for less the 1 seconds. This will be enought to restore the residual magnetism to the rotor and the unit should be producing power now.
Nov 17, 2009 | Coleman Powermate Premium Plus 6250W...
Three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Apr 01, 2009 | Coleman Powermate Powermate 5000W...
I have a Coleman Powermate 5000 / No power output
Two suggestions. One: check for voltage from the secondary coil wires (if it has one). Two: unless stated do not do this, I have always flashed the excitor circuit through the 120vac receptical. Give these a shoot and I hope it works for you.
Mar 30, 2009 | Coleman Powermate Powermate 5000W...
Generator output
Hi, You don't say whether this is under load or not but if not is within the acceptable range, which is +/- 10% . Generally speaking, voltage on a generator is not the issue but the load which it will carry, hence their wattage ratings. Measure your household voltage and you will see that it varies from day to day but usually stays within the limits and your electrical panel is rated in amperage. Hope this answers your question!
Feb 07, 2009 | Coleman Powermate Powermate 5000W...
RIM BlackBerry  Pearl  8100 Logo
649 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
