Question about Zebra 110Xi III Plus Thermal Printer
I have a new GK420t printer. I am using WASP
I have a new GK420t printer. I am using WASP Labeler program. When I go to print I get an error and it won't print even though the GK420t is selected. I downloaded printer system direct from Zebra. I'm not really sure what I am doing wrong. HELP!
Thanks - Debbie
4 Suggested Answers
  • 185 Answers
SOURCE: Prints larger that print preview shows...
Firstly make sure your using the correct drive ZM400 rather than Z4M. if you are using the applications driver make sure of headers and footers sizes and the print area is set correctly. If your using odd sized lables download some new drivers from the Nice Label website, they are far more adjustable that the standard Zebra drivers.
Posted on Oct 29, 2009
  • 50 Answers
SOURCE: I have a Zebra GK420t Alternately Flashing Red and
From the owner's manual:
Alternately Flashing Green and Red: Needs Service 8
8. FLASH memory is not programmed.
• Return the printer to an authorized reseller
You can find the complete owner's manual on Zebra's web site.
Posted on Jul 25, 2011
  • 367 Answers
SOURCE: Have a Zebra GK420T and replaced printhead but
Have you tried reinstalling the printer drivers? You can get them from here. http://www.zebra.com/id/zebra/na/en/index/drivers_downloads.html
Sometimes drivers get messed up configuration settings and a simple reinstall will fix it. There may also be some firmware updates for your device (also available on the same link I posted).
Could also be a damaged printer cable. If installing the printer driver again did nothing try replacing the cable.
Chris
Posted on Aug 15, 2011
Zebra GK420T Red light keep flashing
Seems its loosing calibration, try to reset to factory defult setting and it will calibrate with the labels that have at the moment. Please check settings at windows drivers (should be set up at Thermal transfere if using ribbon otherwise Direct Thermal if not using ribbon.
That issue can happen aswell if when sending a job to the printer with wrong settings, it will overrwrithe the previose settings of the printer.
you can untick the setting " use printer settings" at drivers as well.
if you need diferent driver go to www.seagulldrivers.com - this driver let you to resett printer to factury defaults. Hope it helps.Paulo.
Apr 03, 2014 | Zebra GK420t thermal transfer and thermal...
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
I have a Zebra GK420t Alternately Flashing Red and Green light error message. How do i clear this.
Jul 25, 2011 | Zebra GK420t thermal transfer and thermal...
Hi, when I try to print to a networked GK420t, it prints the first page then feeds two and a half labels and then flashes a red light. At which stage it completely loses network - pings time out.
The problem that you are facing can be resolved by doing a reset on the printer and then setup the printer on the network again. This will resolve the issue.
Jul 05, 2011 | Zebra GK420t thermal transfer and thermal...
I have a GK420t Zebra Thermal transfer printer that prints the test print perfect but when connect to mainframe and start printing from mainframe system the print is upside down. The top of print is on the...
You need to add the ^POI or ^PON command to your format on your host system. Look it up in the manual to see which is right for your app.
You could also get labels that are wound the other way on the roll. Inner wound vs. outer wound.
Jan 05, 2010 | Zebra GK420t thermal transfer and thermal...
Aug 29, 2009 | Zebra Z4M Printer
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
Zebra 110Xi III Plus Thermal Printer Logo
111 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
