Question about Microsoft Windows XP Professional for PC
Possible causes of failure in booting PC
Gentlemen,
what are possible causes of the Blue Screen of Death ? as well as constant fragmentation of HD ?... Thanks for any hints !
  • Microsoft Master
  • 12,061 Answers
There are indeed many naby causes for the BSOD, unfortunately... however it is  usually a "Driver" issue, but not always. Often the Display Driver. What you need to do is, remove any thing attached, & try to boot into SAFE MODE,with networking, press F8 at bootup... and then, either,, try a System Restore, back to an earlier time when was OK. OR troubleshoot via the  Msconfig, command. Start->Run->Msconfig (enter) This will bring up a set  of tabs  select startup tab and disable all. Try a restart, if it does, stay in safe mode, then re-enable them, ,  one by one until it hangs up... there is your problem. Remove/Update that software. If that doesn't  work.. It may be a virus too.. do an extensive scan. Sometimes it is handy to run "Housecall"  this is a very good online Virus scanner.
Posted on Feb 01, 2010
  • 2 more comments
  • electronic & computer repair&  servicre
    Sergeant:
  • 206 Answers
Entire books have been written about the infamous BSOD. Fragmentation of are hard drive is generally the result of a crowded HD.
How to help. Have you check your computer for viruses, spyware, etc. Several free programs exist as well as some online scanner.
I have used AVG before with no problem. Remember however that free software does not actively keep your computer clean. They,in effect, catch the virus after it is on your computer. Paid versions include real time scanning of you computer.
Spyware is different and ever present, cookies included. I have used Advance System Care, both the free and paid versions. This programs scans for spyware, registry problems, privacy issues, and cleans junk files. Another IOBIT product , Security 360, scans for trojans, and deep problems. Both have free as well as upgrades for their products. Additionally, each program has other components which can optimize your system, check and recommend security problems and defense, disk fragmentation.
Check also your HD properties. How much free space do you have? If you are less than 50%, you might add another HD. Besides storage for programs and data the HD is used by the CPU for a type of memory. Not enough space and it will slow your computer down and require the HD to fragment any new files added.
Good luck, hope this helps
Blue screen death
Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return hardware settings to default in Device Manager. Unless you have a specific reason to do so,the system resources that an individual piece of hardware is configured to use in Device Manager should be set
to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
Sep 07, 2013 | Advent Computers & Internet
Automatic restart my laptop.Windows vista
If you are able to boot the computer in safe mode, you can disable the Automatic Restart from the Control Panel.
Open Control Panel.
Click on the System and Maintenance link.
If you're viewing the Classic View of Control Panel, you won't see this link.
Click on the System link.
In the task pane on the left, click the Advanced system settings link.
Locate the Start up and Recovery area and click on the Settings button.
In the Start up and Recovery window, locate and uncheck the check box next to Automatically restart.
Click OK in the Start up and Recovery window.
Click OK in the System Properties window.
You can now close the System window.
From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
If you're unable to fully start Windows Vista due to a Blue Screen of Death error, you won't be able to disable the automatic restart on system failure option as described in the steps above.
Try the steps below:
Just before the Windows Vista splash screen shown above appears, or just before your PC automatically restarts, press the F8 key to enter Advanced Boot Options.
You should now see the Advanced Boot Options screen.
Using the arrow keys on your keyboard, highlight Disable automatic restart on system failure and press the Enter key.
After disabling the automatic restart on system failure option, Windows Vista might continue to load. Whether or not it does depends on what kind of Blue Screen of Death or other problem Windows Vista is experiencing.
Since you disabled the automatic restart on system failure, Windows Vista will no longer force a restart when it encounters a Blue Screen of Death.
Now that you have the STOP Code associated with the Blue Screen of Death, you can troubleshoot the problem:
The following is the list of BSOD error codes with troubleshooting, you can find the troubleshooting steps using the error codes in the MS website also..
http://pcsupport.about.com/od/findbyerrormessage/tp/stop_error_list.htm
Hope this helped you. Please do rate me.
Thanks!!!!
Dec 21, 2010 | Computers & Internet
Hey do you guys know any tech does work voluntary to fix blue screen problem
3 Easy Tactics on How to Fix Blue Screen of Death The famous windows Blue Screen of Death(BSOD Error) can be fixed with 3 types of Blue Screen Death Repair. Try to apply the following tactics when the blue screen death occur before you call a computer expert for help.
1. Uninstall any programs which you had installed recently.
Sometimes, there exists a conflict in drivers installed on your pc that causes the blue screen error to pop up. In most cases, this does not occur, but if it does, Windows offers you a roll back feature where you possibly can bring your PC’s operating system back to its original functioning state.
2. Random Access Memory is faulty.
When the Random Access Memory is faulty, the Computer stops functioning everytime when the RAM is accessed by the CPU. This brings about your PC to halt almost at Random. A simple solution is just to remove 1 stick of RAM and see if the problem goes away. If it does, your PC is fixed!
3. Repair Registry Errors to fix the blue screen of death
Over time, the registry of your windows will get messy with tons of data because you always install and uninstall programs or applications. When you experience slow performance in your PC during boot up times, opening up of new files, surfing internet and blue screen of death, its likely that your registry has a ton of information which needs to wade through. Therefore, it is highly recommended to get a good registry cleaner and improve the performance speed of your PC. Errors fixed in your registry can also fix Blue screen of death error instantly.
Sep 11, 2010 | Computers & Internet
When trying to start my computer emachinesE627, i have a black screen that says error loading operating system
The computer can not see the Operating System. This can be caused by several things, so I will just list a few possiblities for you here:
If you have a USB flash drive or external HD plugged into the PC. Remove it while the computer boots. Some machines are set to boot from a flash drive and will search for an operating system on it and display NO OS if the bios can not find one.
If the Hard drive has been removed or replaced recently then the Jumper settings may not be correct on the new drive.
If the computer was having trouble booting periodically, freezing or experiencing blue screens before this message, then you may have HD corruption or possible disk failure. With HD corruption you only need to run chkdisk /p within recovery console in XP or run the Vista recovery center with vista. HD failure is a dead disk, no option but to replace.
Bad RAM or a dead CMOS battery can also cause this type of failure. So check these also.
This can also be caused by a damaged master boot record or primary boot partition. Run fixboot or fixmbr from the recovery console on XP or just run the Vista Boot Repair Console in Vista
Worm Viruses and Rootkits that damage the primary boot sector or the Master Boot Record can also cause the OS to mysteriously disappear. So if none of the above sound like they are for you, then you can try looking for one of these on the affected drive.
Hope this helps,
Gill
Aug 28, 2010 | E-Machines eMachines Monitor E15T4
I am using G60 T HP LAPTOP. NOW I AM UNABLE TO GET THE DESKTOP IN MY LAPTOP WHEREAS IT SHOWS TOTAL BLUE SCREEN
Try repeatedly pressing F8 whilst it is booting and using the safe mode option.
If it boots ok then un-install any recent software changes and try to re-boot normally again.
bsod (blue screen of death) can be cause by many things but there is usually some form of error message either just before or during a bsod.
That complete message would be most useful in diagnosing any further issues you may have.
Aug 18, 2009 | HP G60t with Intel- R Core- TM2 Duo...
ASUS F3F notebook Failure
Hi
Please tell about yous OS then we ll try to solve
Harry
Aug 11, 2009 | ASUS F3F-AP112C CORE 2 DUO T5500 1.66GHZ /...
Dell D600 won't complete startup. It gets to the Windows XP screen with the blue scrolling bar, and then it freezes. Any ideas?
Blue scrolling bar continues or does that freeze too.
If not you booting with a cd in the drive is the HD light winking at you?
Is your HD fragmented to the point where you have less than 3/4 free space on it?
Aug 02, 2009 | Computers & Internet
Constant blue screen when I attempt to boot up
oh..you have encountered the "Blue Screen of Death" - BsoD . This s a general prob in Windows systems. Try formatting ur drive and reinstall the OS. The bad sectors in ur HDD wud have caused such a blue screen.
Mar 28, 2009 | Dell Inspiron 6400 Notebook
It is the HD thats is the cause of you blue screen of death. To fix this problem you must run a scan disk in windows and let it repair the problem. If you cant repair it through windows you will have to use your windows disk. Boot Pc up with windows disk in CD Rom and fit F-12 select boot to dvd or cd rom option. Select repair windows, then you should get a black screen with comand line like a DOS screen. Type in C:/Fixdisk.
Jan 02, 2009 | HP Compaq Evo Notebook N600c
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
