Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
I'm losing hot water pressure at all faucets in house. I drained tank, and no sediment/rust came out. The hot water outlet line to tank is hot, and so are lines throughout house to faucets. This problem started a month ago. I would lose pressure, then after about an hour, everything worked like it suppose to. Pressure would be fine for a week or two, then I would lose pressure again for an hour or so. Then everything would be fine for a while. This time, the pressure doesn't seem to be coming back. I have noticed that the cold water shutoff on tank is starting to leak a little. Can anyone tell me 'how' to fix this please? Thank-you, Keith
Just curious, im a plumber by the way. do you have a water softner
Posted on Feb 03, 2010
Drain hot water heater
turn off gas
turn off cold water to heater
connect hose to spickot
place hose end outside
turn on spickot
open hot water faucets in house
wait.
when water stops, turn on cold water for 30-60 sec or so to try to stir up any sentiment in tank
turn off cold water and let drain.
close spickot
turn on cold water
let fill till water start coming out hot water faucets then turn off hot water faucets.
turn on gas and relight pilot.
finish bleeding air from hot water faucets.
set water heater thermostat
Jun 14, 2014 | Rheem 43VP50E2 50 Gallon FVR Natural Gas...
How to clear Major plumbing clogs
I am assuming that you are referring to a calcium or rust build up in the water heater.
If you are having this issue you will need to turn off the water to the heater. You will need a garden hose, access to a outside water soucre, cold water is fine.
Shut off the gas or power to the hot water heater before starting.
Now you will need to place the garden house on the drain fitting on the water heater, placing the end of the hose outside and lower than the drain valve. Open the valve and drain the heater, you will need to open a hot water faucet to help drain the heater. I don't suggest opening the TPR ( Temp Pressures relief )valve due to the fact that they sometimes leak or don't reseal after opening them.
Hopefully the drain valve is not clogged, you should hear and see water exiting the garden hose.
If you are not getting any water from the drain valve you are going to have a challenging task.
If no water is coming out, my recommendation is to get the required tools to remove the hot water line from the top or side or the heater, also a few towels to soak up water A bucket is helpfull also.
remove the hot water line, then you will have to use a small hose to siphon the water from the tank. Once the tank is empty you can then remove the drain valve and replace it.
once you have replaced the drain valve you should ensure that it's closed and use a Gallon of CLR. Poor this into the water heater through the hot water outlet where you removed the pipe from. Now make sure the faucets are closed and replace the hot water line. You can now turn the water back on to the water heater.
After a few minutes open a hot water faucet to let out any air until water flows out, than close the faucet.
Let the water heater set for a few hours, then drain the tank!
when the tank drains, close the drain valve again and refill the water heater. Once again open a a hot water faucet and let the air out till the water heater fills. Again let sit for a hour.
At this point open a hot water faucet at the farthest point from the heater and let the water run for 5 min. , than close it and move to the next closest faucet and repeat until all faucets have been opened and run for 5 minutes.
If you still have a slow flow in a faucet, you may need to repeat the CLR step.
I also suggest that you remove all faucet screens and clean them.
If you still have a clog than you are going to have to remove or replace a piece of water line in the house. The blockage may be hard to find but if you have access to most of the pipe or it's visable you may be able to hear the blockage with the water on. Otherwise this will result in using some water line taps and a pressure guage to find the blockage.
Oct 17, 2013 | Mountain Plumbing Water Heaters
Low flow trough the heater
follow this steps and fix it. God bless you
Drain a tank:
  1. Shut off power at the electric panel and post a sign warning others not to turn it on.
  2. Close the cold-water supply valve and open a hot-water faucet somewhere in the house (to speed draining).
  3. Attach a garden hose to the drain valve and run it outside the house.
  4. Open the drain valve and allow all water to drain out.
  5. To refill the tank, close the drain valve tightly and open the cold-water supply valve. Also open a nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full and the faucet can be closed.
  6. Once the tank is full, turn the electrical power back on.
Test and replace a relief valve:
  1. Lift the spring lever on the valve to fill a small cup. Check the cup for sediment.
  2. If no water spurts out, or if water continues to drip after the valve is released, replace the valve.
  3. Cut power at the electric panel and post a sign warning others not to turn it on. Close the cold-water supply valve.
  4. Drain a few gallons of water from the tank.
  5. Unscrew and remove the discharge pipe if used.
  6. Loosen the relief valve with a pipe wrench, then remove the valve by hand.
  7. Apply pipe tape to the threads of the replacement valve and screw it into the tank by hand. Tighten it with a pipe wrench. Screw the discharge pipe (if any) into the valve outlet.
  8. Refill the water heater and restore electrical power.
Oct 08, 2013 | Water Heaters
When I run hot water for the tub, it has a brown tint
10 year old homes today usually do not have galvanized pipe. They have copper or pex plastic pipe. These do not rust.
Is rusty water on both hot and cold line, or just hot line?
Just hot line, then check anode rod and flush tank:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
Are you on water well? Well casing can get rusted. Water can have minerals. Call local water well service and describe problem in detail.
Are you on city water or mudd district water? Is pipe coming into house made of galvanized? Look inside meter box or look at pipe coming into house. Sometimes the city water line at end of run can get filled with sediments that will discolor water. Have water company flush the city water line.
May 04, 2013 | Rheem Water Heaters
Rust in water heater tank
the tank needs flushed out ! heres how. Water heater manufacturers recommend flushing sediment from your storage type water heater periodically.
If your water heater is gas, set the gas valve to "Pilot" to prevent the burners from coming on while you are flushing it. If your heater is electric be sure to turn off the circuit breakers. With an electric water heater, if the water level drops below the heating elements and the thermostat turns the elements on, the heating elements will probably burn out quite rapidly. Connect a garden hose to the drain valve at the bottom of the tank, Close the shut off valve on the cold inlet to the water heater. open the temperature/pressure relief valve at the top of the tank by lifting the lever. Leave the valve open. Open the drain valve at the bottom of the heater allowing the water to flow out through the garden hose. when the water is clear your finished. close pressure relief valve on top of tank and turn water back on.
Open a hot water faucet in your house, and let it run until no air bubbles come out.
Turn the heater back on, and with gas units re-light the pilot light if necessary. good-day !
Apr 24, 2012 | Water Heaters
I am losing water pressure, but only on the hot side. Cold pressure is fine, as you add hot the pressure fades, the hotter the less pressure. This is at all points in the house. The water heater was...
You have a clog in the hot water line.
If problem is at one faucet, then remove aerator and clean, then disassemble lines underneath sink.
If problem is at every faucet, then that moves search close to water heater.
Look at hot water line that exits water heater and trace that line to first Tee.
Look at cold water line that enters water heater and trace that line to Tee.
Clog is located between those 2 Tees.
Buy pressure tester that connects to hose thread.
Connect pressure gauge to hot water heater drain valve.
Then conduct same test you did at faucet.
See if pressure drops at tank.
If pressure drops, then clog is on cold side of tank, and probably hot side too.
If pressure does not drop, then clog is on hot side of tank.
Suspect 1 is any place two different metals join. For example galvanized pipe and copper.
Suspect 2 is supply pipes that exit top of tank. Take apart and look inside pipes for corrosion and sediment lining pipe walls.
Suspect 3 is elbow. Disassemble pipes and look for sediment and flakes of rust.
Suspect 4 is all suspects above, each having sediment and corrosion.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 19, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
White sediment in the hot water
replace heater-have u ever drained heater?turn off water supply-drain heater .try this a couple times.if u replace heater put water filter on incoming water.
Jan 07, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
188 people viewed this question
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
