Question about KitchenAid KGRA806PSS Gas Kitchen Range
My KitchenAid KGRA806PSS Stove's Burners won't light. And the stove gets up to 200 degrees but no further.
  • 619 Answers
Bad power source. Not getting 240 volts to oven. reset breaker by turng off the back on for the stove. 240 volt double breaker. If this doesn't work problem will be where stove plugs in.
Posted on Feb 02, 2010
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Where is the service manual
check the back of the stove up on top,if not there pull out the bottom draw,check the back of draw,check the opening where the draw slides into,could be taped to the frame or if someone worked on it they could have taken it,it should be in a plastic bag taped somewhere in the spots i told you.good luck if nobody else worked on it hopefully it will be with the stove
Jan 06, 2012 | KitchenAid KGRA806PSS Gas Kitchen Range
I have a kitchenaid gas stove 30"wide model# KGRA806PSS01 and the problem its having is that the bake and broil igniters will not spark to light the gas the top burners are working just fine and I...
Unfortunitly i myself a tech of 30 years has no idea what the code 0164 means and have only ever see error codes with E/F so on that sorry no help. HOWEVER having replaced the spark module and EOC i would suspect the only thing else that could be causing the oven/broiler to not ignite is the electrodes(igniters) and would go ahead and replace those as well.
GENE
Sep 23, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
Same thing with my one and 1/2 year old KGSS907 series stove
Yes it is fixed. Did a temporary jumper of the over temp fuse to use the oven one night. Installed a replacement 130 degree fuse with a mica transistor insuator under it instead of being mounted directly on the back side of the oven. This raised the range to about 150 degrees.
Thanks for the help
Aug 25, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven door is locked
i took the grids off the burners and gently pushed a screwdiver in the gap between the top of the stove and the area where the lock is. Then i slid the lock to left. Presto! open!
Feb 29, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Oct 15, 2007 | Frigidaire FED300AS Electric Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
272 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
