I HAVE A jWin DVD PLAYER M/N JD-VD736. WHEN I PUT IN GOOD DVD'S WHICH WORK IN OTHER PLAYERS, I GET AN ERROR (WRONG DISC). HOW DO I CHANGE THE SCHEME SO IT WILL ACCEPT THE DVD'S? THANK YOU RAY PLEASE SEND AN ANSWER TO RAYW34@TWCNY.RR.COM OR CALL 315 342 5655 '
  • 5,138 Answers
Theres Nothing you can do, Some DVD players were designed to Play only Orignal disc and will not play Bootlegged disc.
Posted on Feb 10, 2010
My jwin model jd-vd509 does not play all regions,how can i change that? iwas given player in macau in macau as a gift,but find that the origanal dvd`s i bought in the uk and australia wont play,it comesn...
Don't know if it will work on your. I have a jWin JD-VD141 and the code works. Have the DVD tray open (means ejected) then press 9735. A menu will pop up and choose Regions 0 then exit. You DVD player should play DVD from all regions.
Dec 08, 2009 | Jwin JD-VD509
I have jwin jd-vd503 it does not work it shows
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
  1. (Open the disc tray)
  2. Press SETUP
  3. Press 1, 3, 6, 9
  4. Press LEFT 3 x
  5. Press RIGHT
  6. A new menu entry appears (Version)
  7. Select it and select RC (0=codefree)
Sep 15, 2009 | Jwin JD-VD502 DVD Player
Won't play DVDs from asia .. need region code unlock.. help.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
Aug 22, 2008 | Jwin JD-VD135 DVD Player
No signal on tv
Manually change the TV to the relevant AV channel.
Also you don't need both the S-video and the yellow RCA connection. Use one or the other.
May 03, 2008 | Jwin JD-VD135 DVD Player
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Batt
Check http://www.batteryvalues.com/ or do a Google search. There are several online battery suppliers. Note: You should be able to find a specific battery number on the battery pack which will help to ID an exact replacement.
Nov 28, 2007 | Jwin JD-VD736 Portable DVD Player with...
Player Does not play any type of Disc
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
Oct 06, 2007 | Jwin JD-VD149 DVD Player
Playing PAL system dvds
Turn unit power on
with dvd draw closed and with no disc
press 9735
hidden menu appears
select REGION 0
exit setup
for multi zone compatibility and enjoy...
Sep 21, 2007 | Jwin JD-VD149 DVD Player
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
