Question about Liebherr Refrigerators
Water dripping inside back of top compartment
I have a (Manual says C16,CI16,CS16,7080 361-02) Liehberr
refrigerator about 3-4 years old. Inside from the top back water runs down the back of the top compartment
and pools in the lowest drawer. What do I do? I'm not able to remove the top
cover to the lighting system.
Thank you
    Scholar:
  • 111 Answers
It looks as if your drain tube has stopped up and the water is finding the next easiest route. The drain tube runs from the freezer area, down the back of the fridge to the lower area near or on top of the compressor where it evaporates. Some food may have gotten stuck in the tube. If you can get to the back of the fridge and see the tube (it may be in the wall) you may be able to dislodge it. There also may be a place in the refrigerator where it drips from the freezer to a funnel in there. It depends. But that is normally what happens when the refrigerator goes into defrost. It fires up cow-rod coils in the freezer area and keeps the frost off the coils thats why they call it frost free. the water then runs down the tube. Start checking there first.
Posted on Feb 01, 2010
2 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: fridge and freezer display shows ON and not
Hi, if the display is supposed to show the temperature of the fridge/freezer on the display then what appears to have happened is that the remote temperature bulb has come out of place. If you can get to it you may be able to put it back in place. You will have to start at the display and will see the temp. cable and follow it back to see where the bulb is now resting. If it is not exposed for you to be able to excess it, I would call asap from where you bought it as it is new and tell them about this condition! Keep me updated on this please.
Sincerely,
Shastalaker7
PS It would not be the compressors unless the unit is not cooling at all then you could have a serious problem.
Posted on Jan 17, 2010
Dripping water
Mine had the same problem today. I found the drip tray under the screwed on panels in the freezer was full.
There is an evaporative tray above the compressor in back, and feeding that was a drain pipe that was blocked with crud. Removing and cleaning the cap made it flow freely again. Hopefully that fixes it.
Jan 23, 2014 | Sanyo SR-1030W Top Freezer Refrigerator
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
Water dripping in refrigerator from ice forming in top rear of refrigerator. Ice has formed below what we think is the automatic defroster and is dripping water into the the main part of the refrigerator....
You have a drain clogged at the bottom of the evaporator inside freezer compartment. You'll need to remove all contents put towel inside, turn off, pull out to access back of fridge, pull drain line off or check at bottom in pan where it normally drains, you can melt ice at top of tube with hot water,hence the towells. this is a messy job usually takes about a good hour to get it right, just perservere. I will fix it, when you get it cleared. I have employed a coat hanger to speed things along as a tech it is the call I dread because of the mess.
Good Luck,Masta tech
Aug 21, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Fridge and freezer display shows ON and not
Sincerely,
Shastalaker7
Jan 17, 2010 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping in refrigerator compartment
This is an indication that the defrost drain is clogged or blocked. Below is a link that will help you resolve the problem. Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Apr 27, 2009 | Refrigerators
Water dripping from freezer when defrost kicks on.
You probably have a plugged drain in the freezer compartment. Open that up and check it. Hope this helps!
Feb 16, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
641 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
