Question about Hotpoint Washing Machines
Wmd 940 wont fill,, water pressure ok,hose ok,f01
Wmd 940 wont fill,, water pressure ok,hose ok,f01 in display after a while
    Sergeant:
  • 215 Answers
Solanoid. does it fill on any other programe. try hot wash, then rinse
Posted on Feb 08, 2010
My Indesit 7105 has flashing H20 lights, have checked but no blockages. It fills and drains fine, It wont agitate though, any ideas?
The machine does not fill with water or 'H20' flashes in the display.
The water inlet hose is kinked. • The water inlet hose is not connected to the water supply. • The water pressure is too low. • The water tap has not been turned on to allow water to flow into the machine. • There is no water supply to the house. • The inlet valve filter is blocked. • The START/PAUSE button has not been pressed.
Faulty pressure switch machine thinks there is no water in the machine.
Apr 01, 2017 | Indesit Washing Machines
I have a code H 20 then it goes to F01
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
F01: Triac Short circuit
Overhaul CNE
Replace Card
Dado
Apr 05, 2014 | Ariston Technologies Washing Machines
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
Fills with water but wont stop filling and wont change to different cycle just keeps filling
check water pressure, it need to be about 20psi. also remove fill hoses and check the screens for dirt. clean it if necesary. also check water valve at fill hose connection. it has screens also. clean if needed. if all is ok then replace water valve.
Feb 07, 2011 | Washing Machines
We are getting a H F when we start the washer and water wont start to fill the tub
Hi
Error HF means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If the machine is not filling then check whether both valves at water source are turned ON and inlet hose are not plugged. If the machine is filling fine then chec the pressure switch hose and the drain hose for siphoning (also make sure water is not flowing back to the machine from drain hose). Check wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU).
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Kenmore Washing Machines
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMD washing machineFault Code F01 machine will not start
Fault code F01 indicates a problem with the motor triac.
Check all connections to and from the motor, the control module, and the motor plug
Jan 09, 2010 | Washing Machines
Bosch exxcel 1400 s express fault F01 and F02 whats the problem here?
F01 Door not closed properly.
F02 Tap not turne on, Inlet hose kinked or pinched, Filter blocked in water inlet hose, Water pressure to low.
Apr 30, 2008 | Bosch Washing Machines
Washing Machines Logo
731 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
