Question about LG Flatron L1750S 17" LCD Monitor
LG FLatron LE15A10 LCD problem
Hie my Lcd is giving a blurred picture ,its just fuzzy , the images are not coming out ok . How do i fix this.My email is pwgabayi@yahoo.co.uk
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
I have lg 1200 flatron golden eye tv. Picture is getting blurred and cloudy appearnce. Pls let me know solution
The resolution is dependent on the settings. Did you check and adjust the pot controls? Check the connections from the source to see if any loose wires are in need of tightening? In some case HEAT causes the controls to go out of sync and give you a poor picture. Other than that, contact LG support services for their opinion.
Jan 03, 2014 | LG Televison & Video
Monitor lcd lg flatron w2252s prende y se apaga a instante
this sounds like you need a new inverter. it sits behind the trim just under the lcd screen. you can get the inverter from most lcd screen specialists or ebay.
Apr 12, 2013 | Computers & Internet
How to open lg lcd flatron L1552S
help what open monitor flatron l1552s ? for fix
Apr 11, 2012 | LG 22" FLATRON LCD Monitor
Dual Monitors - why does my second monitor have bad picture?
As long as something isnt broken, using the HDMI and the D-Sub should be fine. From your fuzzy pictures I suggest that you want to double-check your cables.
Have you tried to switch it? If you put the second monitor on the D-SUB and the picture is still faulty, its very likely the problem is your monitor.
Dec 29, 2011 | LG 22" FLATRON LCD Monitor
MY LCD IS DOING RANDOM BLUR WHATS WRONG WITH THIS? HELP PLS.
usually, there are bloated capacitors on the circuit boards, or loose board solder, this random blur may be the cause of failing lcd panel too..
Oct 14, 2010 | LG Flatron 563LS (White) 15.1 in. Flat...
Picture gets blurred and then disappears.
christian204, Your unit may be 5 -6 years old, and may have developed a problem with it's internal "switch-mode-power-supply" and will need good CCFL backlit lcd monitor tech to repair it. When strange and wierd things start to occur on lcd screens the first place to look would be the SMPS. 12fixlouie
May 11, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
My monitor got bumped in a move and all of the text on the display is now fuzzy....any suggestions?
The picture board on your monitor is malfunctioning that is why the display is now fuzzy, This is a sign that the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 23, 2010 | LG 22" FLATRON LCD Monitor
How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Jun 13, 2009 | LG L1730S 17" LCD Monitor
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
I installed everything from CD but still hv the problem
Mar 23, 2008 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
193 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
