PG 3500 : I own two units and have been pretty successful in fixing minor stuff (cleaning water tubes, etc.) But one unit will not get past the thermal drum, papers do not separate and I have been unable to figure out the fix. Any step-by step diagnostics (or references to the service manual section(s) would be appreciated.
  • 3 more comments
  • New Smile Feb 19, 2008
    I am referring to Fuji Pictrography printers.
    Dear Ginko:
    Thanks for the rapid response. I have all service manuals and have tried the recommended tests and checks, but to no avail. I was hoping that you had a connection to an experienced Fuji repair person or someone who knows the specific step-by-step diagnostic protocol to get at the specific reason that the papers stay mated (donor and receiver) and continue to jam in the thermal section. Do you believe I will be able to identify an individual with such credentials or experience from this site?
    Thanks.
    New Smile
    Fuji Pictrography 3500.
    Thanks. I will be anxious to hear what he/she has to say.
    Sincerely,
    New Smile
    PG 3500 has error codes when paper jams and the common jam code is 5. That is the only error I get with this particular printer problem. When the paper jam is cleared, the error code is eliminated. This printer is somewhat sophisticated and I was hoping to get some feedback from an individual who is very familiar with this printer to save time and effort.
    Thanks.
  • 19,396 Answers
    Brigadier General:
  • 6,966 Answers
Best that I can offer is the possible availability of a Service Manual from another user/guest who has the same unit. Pls see this post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
  • Louie  Role
    Louie Role Feb 19, 2008
    his email address is at the bottom.
  • Louie  Role
    An exchange of tips/information with santila@methownet.com or fujiman or Previz might be to your added advantage. Perhaps aside from emailing (when address is available), you can also request them to be your Tech Buddy.
    Genius:
  • 3,587 Answers
Model number would be helpful
How do i fix a honda landa 3500 pressure washer, when the water doesn't come out when started?
Check out the trigger mechanism. Water should come out at any time, even when you do not have the unit started.
Aug 22, 2016 | Honda Landa PG 3500 PSI Pressure Washer
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
What is this white crustie stuff coming from my water lines, and hiow do I fix it?
It is usually calcium-carbonate and lime.
Once the stuff gets into water lines, it can clog elbows and pipes and cause low water pressure.
If pressure is good, then clean out faucet aerators, and install water softener/filter
Generally a water-softener and filter can solve future problems.
http://waterheatertimer.org/Low-hot-water-pressure.html
If you have tankless water heater, then delime the unit:
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
If you have tank-type water heater, then clean out the unit
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Jun 18, 2011 | Rheem Water Heaters
Dehumidifier AD75USTO Whirlpool. Taking in air but not taking out moisture.Seems to be frozen up inside, etc. Can I get a manuel?
Sorry, but your Model # doesn't match any Whirlpool Appliance in my data base. However, another company may have bought the rights to use the Whirlpool name on house brand that they sell. But, lets get to a solution to your immediate problem.
First turn OFF the MASTER ON/OFF Switch and unplug the unit from the wall outlet and allow the unit to completely thaw, before removing and cleaning the air filter. As, I suspect, the filter is dirty and may be clogged. Historically, this is one of the things that can cause a dehumidifier to struggle and not be able to keep up.
After you remove and clean the filter, remove the water collection bucket and look for the drain tube or hole that drains the water into the collection bucket. Using an 18" long plastic Zip Tie, that will fit into the drain hole or tube. Carefully insert the tube into the drain hole. Continue to push it in and you'll reach a bend in the tubing. Carefully push it past this bend, as far as you can. Then, while rotating the Zip Tie, pull it back out slowly. Be prepared for some water to follow. One word of caution - DO NOT use a wire coat hanger to clear the drain tube.
Reassemble everything and you should be good to go. If however, the unit freezes up again, the compressor may be low of refrigerant gas and it will need to be recharged.
Hope this helps you continue to troubleshoot and solve the problem.
Apr 10, 2011 | Whirlpool Dehumidifiers
Water sensor light keeps coming on even tho tank empty have checked hoses and cleaned large filter at front
try cleaning out the condenser unit, instuctions are on pages 2 and 3 of your manual, if you dont have it download it from the indesit website.
fluff and old stuff gathers in it, if you leave it too long it will burn out the thermostat
instructions below.
Step 1
Open the condenser cover
- grip the handle and pull
towards you.
Step 2
Remove the condenser by
turning the 3 catches, then pull
the condenser towards you. (It is
normal for some residual water
to be left in the tubes).
Step 3
Clean the condenser with running
water over the rear side to
remove any fluff deposits.
Step 4
Replace the condenser unit;
make sure that the unit is
securely in place, that all 3
catches are fixed and that the
position arrows on the front end
of the condenser are pointing
upwards.
Nov 15, 2010 | Indesit IS70C Electric Dryer
My bunn coffee maker is just dripping when it is making coffee. Then the next time it makes it just fine.
Hello, I am wondering how long between times you are stating, as most Bunn commercial units, stay heating 24/7, and if water is not poured into the machine every couple of days, they will evaporate off water that is held in the tank. This drop in water level can cause short brewing, slow brewing, etc.. as the unit relies on a vacuum or suction to brew properly. You could also have a leaking tank gasket, or brew tube gasket, and it is seeping air into the tank, breaking the vacuum/siphon action, and then seals with water, or expansion at other times. Another cause would be scale build up, and pieces are floating in the tank blocking the flow of water, or your spray head may be clogging/clogged, which minor cleaning should take care of the sprayhead, and tube, or a major cleaning necessary for the tank.
Hope that helps, and thank you.
Mar 04, 2009 | Bunn VPR Coffee Maker
Water runs out of the bottom of the unit
Check your plastic water orifice. It is in the hose fitting connected to the outlet tube of the water solenoid. It should be a blue one. Mine was completely eaten through, allowing full water flow, and thus overflowing the distribution tray. I replaced mine yesterday and no more water drips. May as well reflace the filter on the inlet tube of the solenoid at the same time. I used a piece of very stiff, but thin, wire formed into a small hook to remove both old parts. Replacements are readily available from multiple sources on line.
Feb 05, 2009 | Aprilaire 700 Humidifier
Icemaker not functioning, water leaking from back of unit
Sounds as if the fill tube is frozen over. Pull the entire fill tube out of the refrigerator to defrost it or defrost it from the inside of the freezer.
Feb 01, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Cuisinart Coffee Maker Model # DCC-1150
Unplug for longer than 15 minutes to completely reset it
Oct 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Leaking water
we had the same issue, and it turned out that our filters inside the unit (the indoor unit) were pretty dirty and needed a clean, and also the run-off pipe/hose was blocked with a sludge, etc. We had to clean the filters inside just with warm soapy water and then blow up the hose outside and it fixed it pretty much straight away.
handy tip - take your mouth off the hose quickly, as the sludge will come out of there pretty quickly as the handy one found out!
Aug 18, 2008 | Fujitsu 18C1 Air Conditioner
Computers & Internet Logo
70 people viewed this question
Alun Cox
David Payne
David Payne
