Question about Electric Bicycle Motor, Bike,electric Bicycles ,kits
Red light coms on on throttle control but no movement at wheel
Red light comes on at throttle control when throttle control is moved no movement at the wheel
  • 4,070 Answers
There is probably a loose or bad connection, possibly at the on off switch. You can try wiggling the wires going into the switch or unplug them and by pass the switch by connecting the wires directly.
Posted on Feb 01, 2010
How do I fix the cruise control
Your question is vague so I do not know if I can help you.
Try checking the cable that comes from the cruise control and mechanically pulls on the accelerator linkage under the car bonnet. It should be clamped firmly to the accelerator cable and the chain link to the throttle has to be tight if it is loose the cable can't move the throtle.
This was the cause of my cruise control not working as the clamps were loose and the cable moved rather than the throttle. Check the brake switch has the cruise control sensor wire connected securely.
Is the car rear wheel drive if so check magnets are still on the drive shaft and that the hall effect transducer if mounted close to the magnets to detect the movement of the magnets. Front wheel drive may use a transducer connected to the speedo cable or may use ignition pulse sensing if these connections fail the cruise control will stop working also. Also make sure the vacuum connection is ok to the cars vacuum piping under the bonnet.
May 29, 2014 | Cars & Trucks
Light is flashing 6 times
Hi,if the controller is a blue finned model called a Rhino, then the following applies...
6 OONAPU Out Of Neutral At Power Up. The throttle was not in the neutral position
when the scooter was turned on. The scooter does not drive.
• Return the throttle to neutral, turn the power off, and back on again.
• Throttle may need to be adjusted (see section 5.1.6).
• Check throttle wiring.
Regards
Rob
www.gewizrepairs.co.uk
And please join me on Facebook https://www.facebook.com/gewizrepairs
May 10, 2014 | CTM Homecare CTM HS-580 4-Wheel Power...
Erratic throttle control
The speed pot and throttle pots do wear in time. These parts are readily available and are not too difficult to change. A service manual can be downloaded from the mnufacturer's website. It has detailed instructions and part numbers.
Feb 16, 2014 | Pride Sonic 3 Wheel Portable Scooter
1997 S10 pickup. When i hit a hard bump front end shakes back and forth. can feel feedback thru the steering wheel with a rattle noise coming from the wheel.
You will need to jack up the front end of the truck and get a helper. Have your helper grab one wheel at the top and bottom (12 and 6 o'clock) and move it back ond forth. You will watch the upper and lower ball joints to see if there is any movement in the j the whole wheel assembly. If there is, they need to be replaced.
Next get your helper to grab the wheel at the 3 and 9 o'clock position and move it again. This time you are lookng for movement in the tie rod ends the connect the 2 wheels to the steering. There are 2 tie rod ends on each side, an inner and an outer, check both for movement. Replace any that have movement.
Have your helper put some muscle into moving the wheel and look at the control arms for movement. You may need to replace the bushings where they connect to the frame.
If ,by chance, you have this truck jacked up and bigger tires, you should invest in stabilizer links for the steering. The Jeep thing known as "death wobble" is not exclusive to Jeeps. It applies to all short wheelbase vehicles like an S-10 or an S-15.
Aug 19, 2013 | Cars & Trucks
Front end shimmy @ 65-70 mph
I would look at replacing your ball joints and/or tie rod ends, either can cause those symptoms. The balls joints should be check by a professional.
To check your tie rods jack one front side of your car check it, then do the other;
Move the front wheels. Placing your hands on the tire at the 9 and 3 o'clock positions, move the tire back and forth rapidly. A properly tightened front end will give no signs of excess movement and should give you the feeling of the entire wheel moving back and forth tight to the hub. If there is a movement, ask a friend or partner to ascertain where the movement is coming from. There could be many places that excess movement in a front end could be coming from. The tie rod ends are the easiest to check. Generally, if there is movement in the outer tie rod end, you will see it moving near the ball area where is sits down into the knuckle of the control arm. Excess movement there will require replacement of the outer tie rod. As far as movement on the inner tie rod, place your hand on that while your helper is moving the tire in the same motion described above. Determine how excessive the movement is, if any, for an inner tie rod. Some vehicles will give off a little movement in the rack and pinion. Some vehicles will have what feels like excess movement, but have pitman arms and idler arms that will also need to be checked. Those components should only be allowing side-to-side movement.
Take some time and make sure the lower ball joint is not moving. Place your hands on the tire at 12 and 6 o'clock and try to move it up and down. Many vehicles nowadays have wheel bearing hub assemblies, and there should be absolutely no free-play whatsoever. If there is and the lower ball joint is not moving in the knuckle, chances are there's movement in the bearing. Some rear-wheel-drive vehicles have a bearing seated rotor and this can be adjusted to tighten the looseness in a bearing; however, a little movement in that type of application is generally OK.
Nov 25, 2011 | 2001 Buick LeSabre
I just replaced the battery & had it arc. The check engine light is on. the gas pedal has no effect. But it will move forward in idle.
check your Electronic throttle control unit and its electrical supply. the Electronic throttle control is located on the LH of the throttle body. Check all fuses and relays for shorts, there may be no power to the Electronic throttle control, which results in NO throttle movement. Hopefully this helps
Aug 04, 2009 | 2003 Toyota Tundra
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Does not move cursor, some times it moves but no control
You don't have to take it apart to clean it. The ball is designed to be removed from the unit by releasing it from the bottom of the control. Then you just simply clean off the red area with a cloth. Do not use alchohol on the surface. It could damage the unit.
Feb 17, 2009 | Logitech Cordless TrackMan Wheel Mouse
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
41 people viewed this question
Top Electric Cycling Experts
Colin Stickland
Colin Stickland
Michial Gueffroy
Are you an Electric Cycling Expert? Answer questions, earn points and help others
