Question about Samsung HLP4663W 46" Rear Projection HDTV
When switched on the picture briefly apperars
When i switch the tv on the picture appears briefly then goes blank but the sound remains. you can see movement on the screen from an angle but its like it should be back lit or something can you help? its a samsung LA40N8
  • 69 Answers
If this is a lcd flat panel the invertors for the backlights have failed
Posted on Feb 07, 2010
Upon power on from the mains the TV goes into standby mode as expected. Red LED light appears in bottom right of tv. When then switching on the RED briefly turns green and then disappears. This has...
Hello
There's some kind of circuit fault and it overheats,Sound like the power board on the tv need to be replaced. You can call or email the manufacturer and see what they say. Also get a cost estimate for the repair. It might not be cost effective in repairing the tv, due to the price of labor.
Jun 12, 2011 | Televison & Video
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
My samsung le40r73bd tv has developed a fault the tv switches on and you get sound and picture then after approx 2 minutes screen goes blank and sound remains other times tv comes on with sound but no...
there is a problem on your inverter board and the cold cathode lamp.The inverter board is the supplying high voltage supply to the cold cathode lamp.This cold cathode lamp is the illuminating the screen in which the the picture will appear once cold cathode is lit.here is a link where you can buy the parts.. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
  2. http://s807.photobucket.com/home/budm/allalbums
:Good luck hope this helps you..
please rate my help
Jun 14, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
42" LCD TV no picture.Have sound
inverter panel is faulty you can probably source another via ebay if your confident on fitting it could be expensive otherwise
Dec 12, 2009 | LG 42LG50 42 in. LCD HDTV
No picture sound only
your lcd tv is most likely not getting enough reception for the visual signal, try switching your tv back to analog signal (not digital) if you can by switching off av on remote, do you get your picture back, if yes thats your problem check your aerial, aerial leads and plugs, also do you have an aerial amplifier plugged into a power point, is it turned on to aplify signal.
Jun 22, 2009 | RCA L26HD32D 26 in. LCD HDTV/DVD Combo
Goodmans GTV30W2LCD Sound with no picture, screen flashes up at switch on then again goes blank.
mine has just done the same thing, i had someone look at it and he said the picture had gone. its not worth repairing it as it cost more than the tv is worth. your better off buying a new tv.sorry.
Apr 15, 2008 | Televison & Video
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
106 people viewed this question
Jerry Greenberg
Jerry Greenberg
