Question about Hotpoint Dryers
Im trying to replace the belt on an indesit condenser dryer model number is70c the drum has stopped working and this is the option im looking at
  • Hotpoint Master
  • 3,463 Answers
To gain access to the drum and belt, remove top cover and right hand side panel looking from the front.There you will see the main working parts.
Posted on Feb 01, 2010
Will not turn on
If your dryer will not turn on 99percent of the time it is because the drum belt has broken.I know that sounds rediculous but the reason this is the cause is because there is a kill switch on the belts tensioner pulley and when the belt breaks the kill switch is activated.Replace the drum belt and your problem is solved
Apr 16, 2014 | Indesit IS70C Electric Dryer
Is70c belt direction diagram
Hi Grant...
I hope this is what your looking for, I do not have your brand here, but maybe the same routing of the belt applies to yours
Bud
Apr 17, 2013 | Indesit IS70C Electric Dryer
Replaced belt on dryer but drum wont turn even though motor is running
are you sure youve got the right belt for that model dont know if all belts are standard or not its a posibilty you have the wrong belt as im asuming your your turning the drum when empty when you get it over the drum and motor should be really tight hope this helps you
Jan 19, 2013 | Indesit IS70C Electric Dryer
Make a lot of nosie
Hi mervyn2011
Sounds like you have a bearing problem or drum roller/slide problems.
You will need to take the dryer apart to determine which problem it is.
For an owners manual go to the following webpage
Please take time to rate me
Bud
http://www.indesit.co.uk/indesit/_pdf/manuals/19504260005_UK.pdf
For parts go to the following webpage.
http://www.ransomspares.co.uk/parts/brands/indesit/tumble-dryers/is70c/
Oct 16, 2012 | Indesit IS70C Electric Dryer
My drum in my indesit is70c has stopped rotating
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 13, 2011 | Dryers
Hi I have an Indesit is70c dryer it seems to work fine for 10-15 mins but then trips the fues box in the house as it cuts out. I've had a look for at the fuse and have cleaned out all filters / condensers....
Do not overload the dryer as the motor can struggle and try to draw to much power.which could cause the trip to go to out, only load drum half full.....this applies to washing machines as well"NEVER OVERLOAD THEM" with washing machines it can affect the quality of your wash as well as putting extra strain on the motor.
Nov 08, 2017 | Indesit IS70C Electric Dryer
How do i replace the belt which has broken on my tumble dryer
Pop the top (spring clips) ... remove the front (screws) ... pull the drum out ... clean everything! ... find the belt tensioner which clips into the floor ... get a new belt ... put it around the drum ... through the tensioner ... around the motor pulley ... reassemble,
Jun 21, 2010 | Indesit IS70C Electric Dryer
Indesit is70c dryer is not heating?
Take off the back plate of the drier to expose heating elements. There you will find two thermo switches, one with a hole in the middle of it. Push something like a pin into this hole until you hear a click. Re assemble back plate and it should work now
Feb 28, 2008 | Dryers
Indesit IS70c condenser dryer
CHECK PUMP AND FLOAT AT REAR OF DRYER EITHER PUMP IS BLOCKED OR PIPE FROM PUMP BUT MAKE SURE THE DRYER IS UNPLUGGED WATER AND ELECTRIC DO NOT MIX,
IF YOU ARE UNSURE WHERE TH PUMP IS GET A QUALIFIED ENGINEER
Dec 25, 2007 | Dryers
Dryers Logo
247 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
