Question about Nintendo Wii Console
Noisey when turned on. Fast clicking sound. Almost a buzz. Otherwise works OK.
    Problem Solver:
  • 5 Answers
If this is when putting in a disk or starting the wii, it's normal. It's just the wii running.
Posted on Feb 02, 2010
I have a proscan 42LA45H 42 in television that has started making a buzzing noise from the back. What is causing this, and what do I need to do to fix.
Hi
If picture and sound is Ok, and only this buzzing sound is heard from the back of the TV, It should be due to core soose of some ferrite cored transformers inside, especially to the power supply regulator board of the TV. Open the back cover of the TV and swtich it ON. Listeen very carefully which transfromer makes the buzzing noise. Just trouch and press the core of the transformer suspected with some non-cunductive material like glass rod, or a stick of dry wood. You can identify the transformer that makes noise by this way. After identifying the exact transformer; switch OFF the set, unplug it from mains socket, apply some "Super Glue" like fast boanding glue to the joint of core of that transformer. Allow sometime for the glue to set. This will solve the buzzing sound problem of your TV. OK
Jul 13, 2011 | Proscan 42LA45H 42 in. LCD TV
Makes a loud buzzing noise when attempting to start cycle
The lock solenoid on the door latch assembly may be hanging up or just noisey. If washer starts and runs then all is ok. If washer wont start, just buzzes, then door latch assembly may have to be changed.
Feb 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
Loud buzzing sound when trying to start washer, something to do with the door, like it won't lock
the buzzing noise is from a one of the coils trying to come in water coil valve cultch coil something is trying to come in but can not go in all the way so it will buzz . there could be a coil that is failing also . put a screw driver on the noisey coil or part to hear what part is trying to engage . change that part or inspect to se way it is not working proper with out buzzing . hope this helps you
Nov 26, 2008 | Washing Machines
Leisure Model DWL T65 Buzzing noise at 1st cycle water entering slowly now no water coming in
sounds like the water inlet solenoid has taken a dirt nap(hence the buzzing noise)if your ok with working on this sort of thing i can help you find the part & we can go from there.otherwise you need to call a qualifyed service tech.hope this helps
Nov 16, 2008 | Dishwashers
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Bzzzing noise coming from monitor
Hi.
It the buzzing is directly from the back of monitor chances are its A noisey transformer.
This can be rectified by mixing up some epoxy resin type adhesive and spreading it over the windings of the noisey transformer.
PLEASE ENSURE MONITOR IS DISCONECTED FROM MAINS SUPPLY when doing this work.
http://dysonmanuals.llc.nu/
Chris..
Dec 30, 2007 | CTX P772 17" LCD Monitor
Noisey printer carriage clicks at left hand end loud buzzing at right hand side
Open up hatch, see if anything got stuck lick staple, paperclip, paper, etc.
If nothing found suggest replacing printer due to cost of repair.
Hope this helps.
Thanks!
Oct 28, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Nintendo Wii Console Logo
65 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
