Question about E-Flite Blade Cx/cx2 Scale Body Sh-60 Seahawk Eflh1271
Cx2 I dont have much forward when I try to drop nose it does not move much.any ideas thanks
How do i check the amperage on my cx2 batters
Posted on Mar 26, 2010
Hercules Helicopter doesn't move forward much
My Hercules is a 3 channel heli,and I will try moving battery forward. On my SYMA s107 I turned the back blade upside down and got a dif style blade. It now goes Forward Great.
Jun 01, 2013 | Toys
1990 lincoln town car air ride issues
first of all the air system is only for the back ,it sounds like a ball join has busted the contianal has air backs front and rear I own to 1990 towncar
Sep 11, 2012 | 1990 Lincoln Town Car
My halo helo will not fly forward.
it is only a 2 channel control, allowing you to fly left, right, up and down so you would have to add some weight to the nose so get it moving forward try to tape different things to the nose so get the right speed let me know what happens
Dec 16, 2010 | NKOK Halo Hornet RC Helicopter
I bought my husband a poulin chian saw but he can get it stated but the chain won't move
Did you ensure the chain brake is disengaged? Grasp the forward most upper handle (hand guard) and move it toward the nose of the bar (forward). Did it click? If no the brake is engaged. Move it slowly aft (it may require some force at the rear extreme to latch) until it clicks. Wear gloves and try to rotate the chain. If it latched and you still cannot rotate the chain please post back (below), and we will explore further.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 04, 2010 | Poulan Garden
Metabo model 6030 will not hammer help out
There are several possibilities. Remove the cover from top of gearbox. The piston / sleeve assembly will be visible. Wiggle the assembly to check for side play. If the assembly is loose side-to-side, loosen one of the support tracks (two allen screws). Wedge a screwdriver between the track and the housing and then re-tighten the screws. Another possibility is that the piston o-ring is worn. stand the tool on its nose, if the piston falls quickly forward, the o-ring is worn out. This part is no longer available. If the piston does not move forward, smack the nose firmly against the work bench. If it still does not move, the piston lube may have dried out. Shoot some WD40 into the sleeve for a quick test. Another possibility is end wear of all hammering parts in the tool. This can be difficult to determine if you dont know what they looked like originally.
May 16, 2009 | Metabo Drills
Rudder control very slow on CX 2
sounds like your servos are weak or just slow you can get stronger and faster servos check with your local hobby store
Mar 27, 2009 | E-Flite Blade Cx/cx2 Scale Body Sh-60...
Antec Phantom 500 burned out
u can buy a ps tester on ebay to make sure all rails are ok 5 bucks for it easy to use great tool to have dont have to be bunrt to have bad rail i seen it
Jan 09, 2008 | Antec Phantom 500 (PHANTOM500) 500-Watt...
E-Flite Blade Cx/cx2 Scale Body Sh-60 Seahawk Eflh1271 Logo
105 people viewed this question
Top E-Flite Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an E-Flite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
