There is no audio on high definition audio bus,how can i fix it,where can i get the software for fixing this problem EliteGroup ECS A780GM-A Motherboard - AMD 780G,...
  • 67 Answers
3 things to check.
Assuming you are using Windows, go to Control Panel, Device Manager,
and check that the audio driver is correctly installed, and then check in Control Panel, Sounds that the correct Playback Device is Selected.
Obviously you will have to reinstall the driver if it's not present.
If you don't have a manual go to the link below download the manual and look at page 56 which tells you how to setup the Audio.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=866&CategoryID=1&DetailName=Manual&MenuID=7&LanID=0
Finally, using the link above go to the FAQ for the motherboard, look at the audio section. There is a bios update to fix no sound output, but do check everything else first.
Best of luck.
If this solution has been helpful please feel free to rate it. Thanks.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=866&CategoryID=1&DetailName=Specification&MenuID=7&LanID=0
Posted on Feb 01, 2010
Hello. i need driver for sound of "elite group 945 gc7-m2" for xindows xp. please sent to me . thanks
Hi.
Here is the link to download the audio driver for your motherboard:
http://download.ecsusa.com/dlfileecs/driver/mb/sound/idt/IDT115.zip
IDT High Definition Audio Driver(WinXP/Vista/Win7_3264
If this helped then please don't forget to rate my help and advice.
Thanks
Sep 03, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I cant find ecs 945 mother board sound driver.
Open the link below provided by EliteGroup;
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=830&CategoryID=1&MenuID=16&LanID=9
You are correct. There is no seperate sound driver.
The sound driver is whithin the chipset Software Installation Utility. However if you feel you must download the software (As a single driver). Open the link provided; http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/ECS-945GCT-M2-V10-IDT-High-Definition-Audio-Driver-040.shtml
Enjoy!
Mike
Jun 13, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
How do i properly disable the onboard video for the "elitegroup a780gm-a motherboard
in your system you can do it by tapping del or f1 while your pc reboot
then in the bios setup you can do it
Oct 17, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Green lines in black/grey screen (only vista, xp runs normal)
It's the onboard video try removing the CMOS battery and placing it back in after serveral hours, if that doen;t work it's the onboard Video replace it with a PCI Express Video Card.
Jul 27, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Problems with EliteGroup ECS A780GM-A (V1.1), a PCI firewire board plugged in a unused slot won't works well. Windows XP recognizes board and installs driver but cannot initialize it and reports error 10....
Hi there.
Error 10 means that the device cannot start.
This can be because the card itself is faulty or you have installed the wrong drivers for it.
Try to locate and install the drivers for it manually and see if it starts then.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Hi .. i got some problems with a780gm-a plz help :
try to re install the audio driver or dowload it http://www.ecs.com.tw/ECSWebSite/Index.aspx?MenuID=0&LanID=9
then if the same problem. check the hardware the audio device
Apr 09, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Monitor doesnt come on--just installed ecs a780GM mobo
Recheck all the hardware connections.
If it fine check the your CPU with another monitor. If it not works then fault with the CPU or software.
Hope this helps.
Feb 07, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
ECS A780GM-A USB Problem
i had a simular problem  turn off your computer  hit the power button and go to bios  make sure the dongle is plugged in  is the computer trying to load from the dongle  disable this item if it is  are you running a raid on this computer if not  select the ide option in bios  you should have three choises  RAID APHCI  IDE  choose IDE and then recheck  thats how i fixed my simular problem  i hope that helps
Jan 23, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
