I have Kodak ESP5200Series All-in- one printer. I had a paper jam and took the back off. It came off real easy, but I can't get it back on. I can't find anything in the manual. Can you help!
  • 73 Answers
Hi please check the below link there is a video to assist you hope this helps
http://www.kodak.com/global/en/service/tutorials/AiOPrinters/ESP/AiOVideos/ESP5200/esp5200_HowTo_Menu.html
Manually clear the paper jam.
  1. Remove the paper from the paper tray.
  2. Turn off your printer.
  3. Wait 30 seconds, then disconnect the following from the back of your printer:
    • AC power cord
    • USB cable (if used)
  4. Remove the cleanout assembly from the rear cleanout area.
    1. Gently press and hold the tab on the left side of the cleanout assembly. I have Kodak ESP5200Series All-in- - p310_0036aa.jpg
    2. Carefully pivot the left side of the cleanout assembly toward you to remove it.
  5. Check the inside of your printer for a paper jam. If necessary, slowly pull the jammed paper from your printer.
  6. If paper is not visible, check your printer for foreign objects, such as paper clips or staples. If necessary, carefully remove the foreign objects from your printer.
  7. Check under the printer for debris or obstructions. Remove any debris and if necessary, relocate the printer to a flat, hard surface.
  8. IMPORTANT: Do not use cotton or cotton swabs to clean the feed rollers.
  9. Lightly moisten a lint-free cloth with water, and gently clean the surface of the feed rollers. Rotate each feed roller with your thumb until the entire surface is clean. Allow the feed rollers to completely dry.
  10. IMPORTANT: If the cleanout assembly is not installed and seated correctly, paper jam or paper tray empty errors may occur.
  11. Install the cleanout assembly.
    1. Insert the right side of the cleanout assembly into the back of the printer so that the tabs fit into the slots on the right side of the cleanout area.
    2. Rotate the left side of the cleanout assembly until the latch snaps into place.
    3. Pull on the cleanout assembly to insure that it is seated.
    Close Window
  12. Open the printer access door.
  13. Remove any foreign objects from your printer, then close the printer access door.
  14. Connect the following to the back of your printer:
    • AC power cord
  15. Wait 30 seconds, then turn on your printer.
  16. Open the paper tray.
  17. Move the paper-width guide to the left.
  18. Pull the paper tray extender until it is fully extended.
  19. Lift the paper stop. I have Kodak ESP5200Series All-in- - esp5250_paper_tray.jpgxya.net/uploads/images/esp5250_paper_tray.jpg" alt="esp5250_paper_tray.jpg" class="h_mi" />
  20. Fan the stack of paper and load it into the paper tray.
  21. Move the paper-width guide to the right until iI have Kodak ESP5200Series All-in- - esp5250_paper_loaded.jpg of paper. esp5250_paper_loaded.jpg
regards
Posted on Feb 01, 2010
How do you open the rear door to fix a paper jam on a Kodak 5250 printer?
There are two plastic tips that you pinch inward at the lower back of the printer. A rectangular plastic piece will come out if you give it a god tug and you should be able to remove any jammed paper. I took mine off and never put it back on because it is aggravating to remove. I also had a problem of every 5-6 sheets of paper would not feed correctly through the printer and a paper jam notice would be displayed. I have all but remedied this too by stretching two heavy duty rubber band around the paper dispensing tray close to the bottom to provide more tension on the paper feeder itself. WORKS GREAT FOR ME! GOOD LUCK! Mine is a Kodak esp 3.2 but it paper jams a lot so maybe this will help you some as well?
Aug 09, 2014 | Kodak ESP Office Equipment & Supplies
I can't unjam the paper on my kodak printer
Just pull it slowly while pressing the button on the printer.
Oct 20, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Keeps coming up printer jammed but no paper in printer
1) Switch off the printer;
2) Try to take out the cartridge, and see if there is paper piece left behind in the rollers since last jam;
3) If you are sure there is nothing paper pieces left, then put back the cartridges in the proper place;
4) Switch on the printer again and try a test print;
5) If it still jam, then you should call a repair technican to fix the real problem which may be caused by the mechanical parts in which you do not have the parts to replace.
Sep 04, 2011 | Kodak ESP 5 Printer
Kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Jul 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My easy share printer dock series 3 is having a paper jam at every photo and only printing half of the photo
please make sure you're using Kodak Xtralife paper - check the back. paper jam and print quality is affected if a different kodak paper is used.
Jul 08, 2009 | Kodak EasyShare One Digital Camera
Paper jam
Yes, put it in the box and take it back, and don't look back. A paper jam is the least of it's problems. Wait till you keep track of the ink you use: 4 4X6 color pictures, and 85 black printed pages before you have to replace the inks. I know , I have one, 3 printheads replaced, and recently Kodak send a rebuilt printer. Kodak has big problems with this.
Get an HP printer.
May 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam in a Kodak ESP- Printer
i had the printer jam issue when there wasnt a real printer jam.
if you push the print cartidges off to the right, then reach in and push down on the cleaning head that is located on the left on the inside, it pops back down into place and voila, printer jam error message fixed.
Jan 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak g600-paper jam
In the book they say to turn off and then turn back on that is supposed to work! ( keep trying that ) try to find a repair shop I took mine apart fixed it but not something I would do again.
May 01, 2008 | Kodak Easyshare Printer G600 Thermo...
Printer jam...i took the back off i see no paper jamed anywhere. I removed the paper and reinstalled it still the light come on saying there is a printer jam
To resolve this issue please do the following:
1. Open the printer access door(the gray part)
2. remove the cartridges
3. remove the printhead, to remove it press the release latch located on the upper left edge of the printhead where you put the black ink
4. Then close the printer access door WITHOUT the printhead and the cartridges.
5. unplug the printer and wait for 30 seconds and plug it back
6. it will give you a missing printhead error
7. install the printhead first, close it and then it should give an error missing cartridges. install the cartridges and if you no longer have the error upgrade the firmware by going to www.kodak.com/go/downloads
I hope that helps. If not contact kodak technical support for further troubleshooting.
Apr 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
