I have just changed two colour cartridges with epson cartridges, and now the printer doesn't print - the paper comes out with nothing on it.
  • wbroome Feb 01, 2010
    i sorted it by turning the machine off, pressing down on both on/off and maintenance buttons, switching the power back on, holding buttons down for further 10 seconds and then letting go. It works now. Don't know why, but many thanks for looking at the problem.
    Brigadier General:
  • 3,917 Answers
First you clean the ink system assembly (Pump and cap) and clean all pipe through porous pad. Or take out the cartridges. Take a piece of soft cloth. Dip it in water. Try to clean the head. Or use the printer software to make Cleaning and Calibration, you can find this under Maintenance label of the printer software.
If problem not solved you need to change print head or send it for repairing.
Thanks for contacting fixya.com
Posted on Feb 01, 2010
Print not clear, double struck, cartridges are new and sometimes paper jams
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/.../trble_4.htm
EpsonPaper does not feed correctly when using the double-sided printing feature. If one of the ... The ink cartridges are not empty. ... If the error does not clear, open the printer cover and remove all of the paper inside, including any torn pieces. Then ... If yourpaper jams frequently, make sure of the following: ... Load a new stack.
Epson Stylus COLOR 600, Top FAQs - Technical Support ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...FAQs...
EpsonThis link provides access to Top FAQs for the Epson Stylus COLOR 600. ... I just replaced an ink cartridge and the printer still won't print correctly. ... [ Answer ]; The printer is not producing any black or color ink. ... [ Answer ]; I'm only getting partial printouts or a "paper out" or "printer off line" error appears. ... How do I clear this?
epson printer problems ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/23851
I loaded a new black ink cartridge into my Epson Stylus C86. .... hit this problem when we first bought it, apparently it needs all colours to print ... i am using Epeon L 110 printer The colour print was good before But now the colour print is not clear ... No paper jams (sometimes paper feeds sometimes it doesn't). it appears that ...
Jan 05, 2016 | Epson Stylus NX420 Inkjet Multifunction...
How do I stop lines on the epson 4515
Cleaning only helps if there is still ink in the cartridges.
If you print the nozzle check, you can see what colour is having problems to print.
And when you are sure there is still ink in the cartridge, you could try to remove the cartridge, and in the printer, where the cartridge was, you could put a drop of cleaning fluid in the nozzle on the bottom. Then try printing one or two pages on full colour, till the ink starts coming through.
Be aware, sometimes just a bit of dust is traveling wit the print head, blocking the ink too. But then you see smear on the paper.
Always be sure the underside of the print head does not have debris traveling with the head.
Almost impossible to see, but epson sometimes delivers special cleaning paper. It is a pice of paper, with a special pice of sticky tape. Sometimes it comes with the Ultra Glossy Photo Paper. Use it.
Aug 21, 2014 | Epson Office Equipment & Supplies
Epson SX110 printer does not print
I assume from your description that the printer is going through the motions of printing but not putting ink from one or more colours to paper. If this is the case please it is likely that the printhead has developed a slight blockage or ceased to function.
-Print a nozzle check from your printers software. This will show you clearly which colours are not printing correctly.
-Run 1-3 head cleans using the printers software with a nozzle check after each one.
-If this doesn't resolve the issue it is possible you simply have a defective cartridge and I would recommend replacing it and trying again.
-If this doesn't help or the problem is across all colours it is likely the printhead is severely dried or has reached the end of its life. So I would either take it to an Epson service center or if the printer is not worth the expense you just keep running head cleans (with 5-10 minute gaps between cleans).
Hope this helps.
Sep 08, 2012 | Epson Office Equipment & Supplies
My printer doesn't print word documents (it doesn't print in black, but it does in colour), it prints everything else. I already checked the port (it's USB), changed the cartridge, uninstalled...
try the following
1.power on your peinter
2.while press and hold the power button ,open and close the top cover times.
printer pick the paper and print the test page and alignment pattern for black and color.
if any of the black or color alignment pattern is not print ,then u have to change the cartridge accordingly.
Aug 01, 2011 | HP Deskjet D2360 InkJet Printer
Bad printing after changing 2 inks also clicking noise not before
shouldn't be the ink. I assume you have an epson as in the picture. my ink refill kit mentions that "epson intellidge chipped cartridges" require an "ink level resetter" to complete the kit. So if you have these cartridges even once refilled the chip tells the printer the cartridge is still empty so you'll need to reset the chip with the ink level resetter.
Aug 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Changing Cartridges does not move into view so I change it
try the on/off button with the lid open. it should move the cartridges.
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
I recently changed the colour cartridge and now the printer wont print colour. Black works - ish. I have troubleshooted and did everything recommended eg clean print heads, nozzles, align heads etc....
Please see the online guide at:
http://support.epson-europe.com/onlineguides/en/sc48/refg/ref_g/
and click on Replacing Ink Cartridges. To change a cartridge before it is low or empty you must press the maintenance button AND the power button at the same time, or use the print utility.
If the new cartridge also fails to produce print, come back with a new comment for further help.
Apr 13, 2009 | Epson Stylus C48 InkJet Printer
Computers & Internet Logo
David Payne
David Payne
