Question about GE Advantium SCA2001BSS Microwave Oven
NEED TO KNOW HOW TO REPLACE DAMPER DOOR - GE Advantium SCA2001BSS Microwave Oven
  • MIKE FULLER Feb 10, 2010
    I HAVE NOT CHECKED THE LINK, BUT WHAT I AM REFERRING TO IS PART 1450 THE PROBLEM WAS THE CLICKING AND LIGHT ON THE INTERIOR OF THE OVEN CAVITY ON THE RIGHT SIDE AS YOU ARE LOOKING IN . IS THIS WHAT YOU ARE REFERRING TO?
    NOT CHANGING THE FAN FROM VENTED TO RECIRCULATE...................
  • MIKE FULLER Feb 11, 2010
    The link you sent will not open................
    Mike
  • 770 Answers
My assumption by your question is that you want to know how to install the exhaust adapter..which has a door in it that acts like a damper to vent either vertical, horizontal or recirculate. I can send you a link that will show the duct and explain how it is installed, the bulk of the info that you ask for will be found on page 5 of this manual...or click on oven exhaust duct on the left hand side...Good Luck! I hope you find this to be very helpful!
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestaType=PDF&Name=003670111.PDF
Posted on Feb 10, 2010
Microwave oven stops after 59 seconds
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp-made models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
If a switch is all you need, we offer a universal type for only $7.50 postpaid which you can order here.
Oct 06, 2011 | Sharp R-1870 Convection/Microwave Oven
Unit shuts down every 59 sec. No matter how much time, with or without anything in micro and I figure to replace motor and switch. How do I get to those parts in unit? Does it have to come down?
Dacor-branded PCOR30-series microwaves are just cosmetically altered versions of the Sharp R1870-series ovens.
These Sharp-made models stop after 59 seconds when there's damper toruble.
See the attached sample drawing below for a typical damper assembly.
We have the applicable service manuals for the Sharp models and have uploaded it to our site here and here to help you in disassembling and troubleshooting your Dacor version.
You can find the Dacor PCOR parts list here and you can order Dacor parts by part number here.
You will have to remove the oven from the wall and remove the outer cover to access, test & replace damper parts.
Just refer to your installation instructions.
If for some reason you don't still have yours, scroll down to the bottom of this page to find yours.
Sep 29, 2011 | Dacor PCOR30 Convection/Microwave Oven
I Have a sharp microwave model # R1874. On the control panel, when I press the start button, the microwave runs for 59 seconds then stops. I have to press the start button again to have it run again. It...
That would be a problem in the damper assembly, either a bad switch or motor, or the damper door is jammed or blocked. Consult the attached diagram for general reference. The damper switch is the same as the primary interlock (door) switch.
Its location varies by model, but you'll have to take the outer cover off to find it.
The best place to order Sharp parts is Tritronics or you can call them toll-free at 866-779-5835.
If you only need a switch, you can order a universal type HERE
Also, I quote other similar solution...
I had the same problem. Turned out to be the micro switch and damper motor. I replaced both myself and fixed the problem for less than $40.00. The best advice I got was replace the switch, reconnect the motor and make sure the motor runs through a damper door cycle. It didn't run, even though it showed continuity and had power, so I replaced the motor which solved the problem. The micro switch which is activated by the cam on the damper motor has to be cycled within one minute, or the unit shuts itself off. The damper motor on my model R-1870 is found in the right rear section of the assembly when facing it. You have to remove the unit, and remove the outer casing to get to it. The damper is a simple sheet metal door, activated by the motor, and the switch mounts at the top of the motor and is activated by the same cam that activates the door.
Good luck.
Mar 06, 2011 | Sharp R-1874 Convection/Microwave Oven
My Sharp micro will stay on for 59 seconds and shut off no matter how long the timmer is set. Sharp model r 1870 It does this every time it is used . The control board has been replaced.
This is not a problem on the board, it is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
Sharp models stop after 59 seconds.
We have the applicable service manuals for these models and have uploaded them to our site here and here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Dec 17, 2010 | Sharp R-1870 Convection/Microwave Oven
Sharp convection microwave R-1870 runs about one minute and shuts off. damper Motor switch?
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
R-1874 shuts down after 59 seconds
That switch is supposed to tell the computer if the damper door is open or closed. If it does not go to zero ohms, the CPU doesn't know what to do. Check the thermistor too...... just in case...
Sep 12, 2009 | Sharp R-1874 Convection/Microwave Oven
Replacing a damper motor - Sharp R967 MICROWAVE AND CONVENTION
The damper should closed when in convection mode and open when in the microwave mode, to keep the heated air inside the cavity.
Aug 22, 2009 | Sharp R-1850A Convection/Microwave Oven
Micro/convection stops every minute
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door could be jammed.
Many models stop after 59 seconds if there's a problem with the damper saystem.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for your Sharp model and have uploaded them to our site here and here to help you.
You will need the
free Adobe Reader to view or print it.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
For the Amana, There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts for the Amana by entering your full model number here.
The Amana's damper switch is called "interlock switch" and is located at ref# 15 in drawing #5. The damper motor is ref # 22.
Nov 29, 2008 | Microwave Ovens
Sharp R-1874 shuts off after 59 seconds
Oct 24, 2007 | Sharp R-1874 Convection/Microwave Oven
Please help with the problem
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door. The damper is a door located on the right side of the innards. The damper closes and opens depending on cooking mode. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find an exploded view by entering your model number here: http://www3.sears.com You can order parts from Tritronincs at http://www.wehaveparts.com
Apr 03, 2007 | Sharp R-1870 Convection/Microwave Oven
Open Questions:
See all GE Advantium SCA2001BSS Microwave Oven Questions
GE Advantium SCA2001BSS Microwave Oven Logo
108 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
