What does it means if the water keeps running nonstop on a washer
  • 12,061 Answers
Usually that means, the solenoid that controls the water flow, has either failed, or the controller for it, has.
Posted on Feb 01, 2010
My amana front load washer just keeps filling. It is running out of the soap fill area. It is giving me code OE. Suggestions on what that means?
Thanks for choosing FixYa and welcome. If the water keeps running, you need to check your water level switch. It may be defective. This switch controls the water level in the machine.
May 02, 2011 | Washing Machines
When you are washing ( spraying ) its fine but when you stop spraying the motor keep on purging the pipes are done up ok the filter and hose are clean can you help??? thanks
These pressure washers are really designed to fail... it is a good idea to NEVER take your hand off the trigger and to wash nonstop as long as the unit is running... it will prolong the life of your pressure washer... if you have warranty on the unit see if they can exchange it for you... if not I don't advise you to take it apart... they are cheaper to replace than fix. Use it until it dies.
Jun 20, 2010 | Karcher K 391m Pressure Washer
Both sides are warmer than should be. motor running nonstop
You refrigerator needs regassing that is why things are not cooling. Your sides of fridge are hot because the motor keeps running to keep what gas is there flowing though the lines trying to cool fridge
May 25, 2010 | Maytag MZD2766GES Side by Side...
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Maytag MAH8700AWW water keeps running
Check the solenoids at the water inlet valve. Use a multimeter or ohmmeter and check the solenoids for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Another possible cause would be a water level switch, but not with it running on only the cold water side. Hope this helps and best wishes.
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
95 firebird formula shoots water out of radiator cap and coolant cap when accelerating nonstop from about 20mph to 75mph or even past 75 mph.... does that mean its overheating? or does it need new hoses...
First it means get a new radiator cap, When the spring goes bad it releases at a lower pressure. You may need a new thermostat as yours is probably stuck open and the water pump just throws the water through.
Jul 14, 2009 | Pontiac Firebird Cars & Trucks
Leaking water
Sounds like ether you have a plugged condensate drain,or the drain pan is rusted out.If it it clogged you can squire a bit of water through to unclogg.If it is rusted youll have to wait it out.Good luck.
Jul 13, 2009 | Heating & Cooling
Cold water keeps running after cycle ends
Your water inlet valve is sticking which means that it needs to be replaced. You can get it at your local appliance store or at repairclinic.com
May 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
