Question about Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each
I have the little gem 4 and its been in the garage over the winter as i've not been out, i took it out today & it wont work when i turn the key there is a constant beeping, i have taken it apart & put it together again but still beeping when i turn the key I charged the battery to full but still no joy it's the type that pulls apart in sections for travelling
  • Drive Medical Master
  • 1,271 Answers
Hi, the rear connections to the main frame are a big cause for problems , make sure the contact are clean and there is a actual connection.
Also check the free wheel lever.
Also you may note that if you haven't charged the batteries for a while , they get weak and may need replacing.
Regards
GeWiz.
Posted on Feb 02, 2010
2001 saturn sl1 wont start on first crank getting worse
How about a repair shop & actually
have the issues diagnosed to find a solution?
Jul 26, 2013 | Cars & Trucks
My 2003 Mercury Mountaineer has an electrical problem. It started about a year ago with the key fob not working, I have bought 3 and all won't work even after re-programing. now tonight I went to
Could be a windshile leak down the A-Pillar & water
gets into the delayed accy relay for the GEM Module
(Body Computer as ford called it for a few years) & you
get what you have now
Try Goolge as I did a few weeks ago for a relative
He had the same issue with the blower being on &
killing the battery
No real fix I found for the windshield leak
Seem a robot didn't put the rubber sealant
on correctly at the factory fo about 5 years
on several fords.
If it isn't water related then the GEM Module
controls all those body features
If you get a used one & match up the numbers,
you supposedly can avoid buying a reman gem
& the expense of having to reflash it to your factory
built combination
Jan 27, 2013 | 2003 Mercury Mountaineer
Engine wont turn over at start
Hi, Do you have an alarm & Immobiliser fitted on your bike as these drain the battery on your bike very quickly? If so i would recommend removing your battery and fully charging it with a decent amp-age charger. If you have your garage attached to your house then i would definitely recommend purchasing a trickle charger and when not using your bike keep this plugged into the mains and you should not have this problem again. all motorbike shops sell these chargers If after this the battery goes flat again i would suggest purchasing a new battery. This is a common fault as most motorbikes sit in the garage through the winter months and if not kept on charge will deteriorate. Hope this helps.
Apr 09, 2010 | 2006 Yamaha V Star 1100 Custom
Gem sound exa 3950 amp
Hi...
If it's a straight-up power switch then it will need to be replaced if it works off a relay then the relay is gone.
website
http://www.gemsound.com/contact.html#
Mar 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Diagnostic Trouble codes...Hyundai xg300
P1191 & P1193: Manufacturer control fuel air metering.
P1607: Manufacturer control auxiliary inputs and outputs
Mar 17, 2009 | 1992 Dodge Colt
Dorr will not shut down all the way
LOOK FOR THE TWO ADJUSTING SCREWA WITH A LITTLE PICUTE OF A DOOR OR THE WORDS UP DOWN.
TURN THE DOWN ADJUSTMENT ABOUT 1/4 TURN AND TEST - DON'T OVER ADJUST YOU WANT THE DOOR TO CLOSE SOLID ON THE FLOOR
HOPE THIS HELPS
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each Logo
260 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
