Question about Vacuums
Can i change the voltage transformer on my rugdoctor widetrack from 120v to 240v easily as i want to import one from the states to keep the cost down
  • Vacuums Master
  • 12,061 Answers
There is NO reason why not. But usually the cost of transformers is quite high.
Posted on Feb 01, 2010
Tip
Rainbow E series cannister wet/dry vacuum
When using a rainbow vacuum it is important not to overfill the water basin with water as it can splash up to high and cause problems at the seperator. The seperator is the metal piece that is located at the bottom of the unit when you take the water basin off it is up inside the cannister. This piece is one of the most important pieces in this machine as it is designed to bring in the air and dirt with out letting the dirt get past it as well as keeping the water out of it as well. Keeping the water level below the plastic marker in the middle of the water basin will help to keep this from happening. When you are done cleaning with your rainbow it is crucial that you remove the seperator by un doing the hand tightened nut at the bottom of it. Hold thr seperator in one hand and turn the bolt to the right. This is the opposite way to undo normal;nuts or bolts but because the separator spins at a high rate of speed it is what is called "reverse threaded".Once you get the nut off the seperator should just come right off easily by pulling it straight down. When you get it off you must take a toothbrush(provided when ou purchased) and you must scrub this clean in order to keep from any dirt or dust getting up into the motor.Scrub the seperator as well as the area that it covers up while installed.this needs to be done each and every time you finish with the machine as you do not want to leave it because it will become rusted right on and it can break the shaft if you have to turn it to hard and if the shaft breaks it can get very costly.Rainbow does not come with a manufactures warranty only a distributors warranty and if you can not find the dist. that sold you the unit you have no one to honor the warranty. This information is stated right in the users manual.my point is if anything goes wrong with it it is most likely going to come out of your pocket. Though the manufacturer is still available the distributor go in and out of business all the time so be aware.
You must also dump all the water every time you finish using your rainbow as it will cause condensation to get up in to the seperator and rust things together. do not store it with the basin that hols the water attached. I hope this will keep your rainbow's running longer and better for years to come.
on Oct 10, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My problem is that Model 16N5-K, 120v 60Hz 12 amp Bissell Vacuum cleaner has no wattage indication in the unit itself, in the box, in the product brochure. our power output in the Philippines is 220v. I...
All the information you need is in your text :>)
Volts, Amp Watts To determine the wattage, use a simple multiplication formula. The ampere (or amps) is the amount of electricity used. Voltage measures the force or pressure of the electricity. The number of watts is equal to amps multiplied by volts.
How to Calculate Wattage (Formula and Tools) - wikiHow
www.wikihow.com/Calculate-Wattage
To find a step down transformer for 1440 watts, you will buy a new vacuum cleaner cheaper.
volts amps watts equation Google Search
Oct 01, 2017 | Vacuums
Rug doctor repair manual
<Consumer.Support@rugdoctor.com> said: "Thank you for your inquiry about a schematic for the Mighty Pro machine. The only place that can be acquired is through Rug Doctor's manufacturing facility. You can contact our manufacturing facility at 800-964-4362 and ask for Parts. They will be able to provide you with what you are requesting."
Rug Doctor Consumer Support
Rug Doctor, LLC ' 4701 Old Shepard Place ' Plano, TX 75093
http://www.rugdoctor.com
Sep 07, 2013 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Digital inverter generator has no 240 volt output
Most power inverters are strictly single-phase. Meaning true 120V or 240V, and no splitting or duplication. It sounds as if your inverter is a single phase 120V, and likely is not stackable on the AC side.
I recommend looking for a Low Frequency Split Phase power Inverter if you want both 240 and 110 volts.
Aug 09, 2013 | Vacuums
From 220V to 110V controller ASM modification, is it possible?
some models and switch behind for convert in that way the transformer had been designed for to do it.
Other models coming according to the country example USA, most of them use 110VAC, other 220VACsuch Europe
However you can ask to the factory by asking if they have a kit for converter to 220vac to 110vac
God bless you
Jul 31, 2012 | Vacuums
120v Dyson DC41 plugged into 240V
You could take it to a Dyson repairer and get a quote.
I suspct it would not worth repairing and converting to 240 volts. Most likely the motor needs replacing and possible other electrical components.
Feb 03, 2012 | Dyson Vacuums
I have a Ferguson step down transformer that takes input as 240V and outputs 115v The model is : TS 115/2000EC I need the wiring diagram for the output side
If it is 240 to 120/115, there should be two high side wires and two low side wires and ground wires, isn't that true?
Please post back, thanks.
Gary
Mar 20, 2011 | Vacuums
My hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Oct 30, 2009 | Numatic HHR-200 Henry Hound Bagged...
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
