Question about Lexmark X4270 All-In-One InkJet Printer
Error #1200----help cannot receive Fax but can send them
  • 4,041 Answers
Hi There
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Hope this resolves your issues.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Posted on Feb 01, 2010
CompuGuy44
  • 432 Answers
SOURCE: Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Posted on Jun 25, 2007
SOURCE: Fax Error Codes
Disconnect all phone lines and wait one minute. Plug in an analog telephone to reset the lines. Re-plug your original phones (and fax) and try faxing again.
Posted on Sep 26, 2007
daemonguy
  • 118 Answers
SOURCE: error #322
## 322 Fuser not heating (Usually Bad Fuser Module)
Posted on Dec 06, 2007
SOURCE: Error is fax full cannot send or receive. Please help !! Hp J6480
I have not found the answer to this in the manual however, you may solve the problem in the following steps:
1. From the Setup menu, choose #6 Tools
2. Choose #6 Clear fax log
Problem solved! Hope you found this answer helpful.
sg
Posted on Feb 24, 2009
laxmankumar
  • 191 Answers
SOURCE: Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
Posted on May 23, 2009
Why cant I send a fax
I share a informative links please visit and check it your error options.
Read More... Cannot send fax using all in one printer and Interpreting Error Codes in Fax Communication Error or Fax History... and If any more Help.. HP Printer Support
Thanks,
Sep 08, 2014 | Office Equipment & Supplies
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
Receiving faxes, won't send faxes. Comes up line
Your fax machine thinks everything is OK. If you can receive you can send.
call the failing fax number with a regular phone and listen for fax tones.
Feb 01, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
Printer can't send or receive faxes
Same problem here - I got it work:
- Error Correction: off
- V34: off
(both Menu -> Fax-Setup - All Faxes)
- detect-dial-tone: off
(Menu -> Fax Setup - Fax Send setup - detect dial tone)
:-) Stefan
Aug 30, 2008 | HP LaserJet 3055 All-In-One Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Comm. Error
Jun 25, 2007 | Canon L120 Fax Laser Printer
Lexmark X4270 All-In-One InkJet Printer Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
