Question about Amana ACF4265 Electric Kitchen Range
Looking for an oven repair manual for the ACF4265A ''The Big Oven'' Amana oven. Where can I find this? My wife opened the oven door and a flash in the upper left hand corner of the control panel flashed. Stove top works fine but the control panel that operates the oven does not.
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
SOURCE: Amana stove stuck in 'lock' mode, door won't open
try hitting cancel is it displaying any error codes like e2 f3 try turning the breaker for five seconds then back on
Posted on Dec 28, 2007
aborcass
  • 2651 Answers
SOURCE: Amana Big Oven Will Not Heat
slow to preheat??? long cooking times??? smell gas while in operation???. all signs of a bad oven ignitor retails for about 60-65. easy enough to replace reomve the lower panle of the oven itself and you'll see the ignitor right there 2 ***** mount that to the bake bar and pull it out, unplug the wire harness, plug in the new one and remount.Start baking
Posted on Mar 10, 2008
ngfam1
  • 639 Answers
SOURCE: I have an electric Maytag,digital
Hi Mearill,
Happy to help you!
At this site you may download a manual !
http://www.maytag.com/support/manuals_literature.jsp
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
  • 80 Answers
SOURCE: Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Posted on Oct 03, 2009
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Unlock oven door on amana ACF4225AW ?
Below is a link to sears parts direct. You can download an owners manual. See parts diagrams and order parts.
After cooling the oven door should unlock.The lock mechanism shows on the second link to cabinet parts.
The switches on the lock are sometimes the cause.
Good Luck.
Manual Amana Electric range ACF4225AW PACF4225AW0
Link to cabinet parts.
AMANA Electric Range Cabinet Parts Model ACF4225AW PACF4225AW0
Aug 24, 2014 | Kitchen Ranges
Amana big oven
use a fulcrum in both hinges (dowel across the oven) to gently bend the thing back in to shape. not a lasting solution, but should be god for a few years.
Oct 15, 2013 | Ovens
Emy amana oven will not immediately ignite. we will turn it on and there is a delay before it ignites and prior to that there is a loud popping noise which even rattles the oven door as if there is gas...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 30, 2010 | Amana Ovens
Oven door will not lock at self clean, I get F-9 error code. This happened after wife tripped into door when open. Is this an adjustment or do I need a locking motor?
Hello there:
This code is a common
F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switchif the latch is alright unplug the oven for 1 hour and the internal reset device will reset the oven then plug in the oven and it should be all right
Sep 27, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana oven model ACF4225AC the big oven power ...
have and Amana oven/stove model ACF4225AC that is 8 yrs old. Middle glass (thick tempered) part # 32028101 completely shattered. Oven was not on for at least a week, noone was near it,was not hit,and at 9 AM while I was in other room it just shattered into a million pieces. Went to dealer- looked up part and found it was no longer available. I have been checking internet appliance part companies, and e-bay to no avail. Cannot find replacement glass. Any suggestions? Thanks, Jim
May 21, 2010 | Ovens
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Amana Range ARG7300W -- igniter problem back??
I am sure you noticed where it is located. A gas oven cycles the same as an electric. depending on the number of times the door is opened and the length of time you operator the oven. Our furnace was acting up one night last winter and I turned the oven on warm with the door cracked open until I could get the part for the furnace in the morning and our igniter went out on the oven. Also try not to touch the element on the igniter when you install the new one.
Dec 02, 2008 | Amana RanARG7302 Gas Kitchen Range
Oven door stuck
To open the door, raise the oven top and use a a flat head screwdriver to open the lock manually.
The door will still lock itself when you close it, so this is only usefull to get your food out.
Oct 19, 2008 | Amana AEW3530DD Electric Single Oven
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Open Questions:
See all Amana ACF4265 Electric Kitchen Range Questions
Amana ACF4265 Electric Kitchen Range Logo
88 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
