Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
F5E1---CODE i AM GETTING WHEN I TRY TO USE THE SELF CLEAN SETTING ON MY OVERN
4 Suggested Answers
iwillfixforu
  • 619 Answers
SOURCE: my oven code is F5E1
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Posted on Mar 03, 2010
heatman101
  • 43501 Answers
SOURCE: Have Whirlpool self clean electric oven model #
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Jan 20, 2011
oldTech2332
  • 2341 Answers
SOURCE: I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Posted on Aug 28, 2011
What can I do for F5-E1 situation
Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
Whirlpool Oven Common Problems and Causes
Jan 08, 2015 | Ovens
Instructions for beko self clean oven
the self cleaning ability of self cleaning ovens is to do with the linings. If yours are getting stained, try putting an oven proof bowl with water in it whilst in use. That should help.
Aug 03, 2014 | Ovens
F11 error code - frigidaire electric overn
Disconnect power for 30 sec, then turn it back on
Dec 09, 2011 | Frigidaire Ovens
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
GENE
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
heatman101
Jan 19, 2011 | Whirlpool Ovens
When I set my oven to self clean it states FSEI. What does this mean?
Hi
F5E1 means the self clean latch will not lock.
Try pressing down any key for 1 minute, F2 may appear, then press CANCEL and see if that clears the fault, if not you may have a faulty door switch.
Dec 17, 2010 | Ovens
I have a whirlpool oven self-cleaning.. get code F5E1 or FSEI, when i set the self cleaning?
I live in apartment with a Whirlpool dishwasher and oven. Today was my first day to do automatic clean. After two minutes the "F5SEI" would pop up, then the door would unlock. I repeated this a couple of times. My mind wondered about a water source; perhaps the dishwater. Fortunately, I had a load of dishes ready to go. So I started the dishwasher, then the automatic clean on the oven. Behold! They work together like homies :)
Nov 15, 2010 | Whirlpool Ovens
My oven code is F5E1 , my oven was in self clean , now the door is locked
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Error F5E1 after self cleaning
Hi There
I have read the codes you are looking for,so I'm sending them to you and i hope this will help.
F5 E1 16 Door latch not operating Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction.Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
46 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
