Question about Belkin (F5D7230-4) Router (587009)
My wireless light do not come on on the router at all.
    Novelist:
  • 108 Answers
The wireless light on the router lits up only when any wireless devices gets connected to this router. It is normal if this is the case.
But, if the wireless light is not lit even after any wireless devices gets connected, then in that case there are two possibilities:
a) LED behind the wireless light would have blown off.
For this, nothing can be done, though you may use the router till it gives you good wireless connectivity!
b) Reset the router (the reset button will be present at the rear end) and then re-configure with the CD.
Posted on Feb 02, 2010
Problem with the Linksys WRT300N Wireless Router No wireless light on router.
No wireless light on your router is a sign that something can be wrong with it, this can be a configuration problem or a hardware/software issue on your router.
The first thing that we can do here to correct the issue is to do a reset on the router and then after that the wireless light back back ON, to reset the router press and hold the reset button of it using a pen or paper clip for 10 seconds while power is ON and then power off and power on the router and check if all the lights are back including the wireless. Then once everything is OK you can now reconfigure the router like running the setup disc.
Jan 31, 2011 | Linksys WRT300N Wireless Router
N Wireless Modem-Router F5D8633au4A: every light on my belkin N wireless router is on e...
WIRELESS LIGHT WILL LIT UP IF YOU CONNECT ANY ANY WIRELESS DEVICE TO THE ROUTER.. FOR EX: YOU CAN SEE WIRED LIGHT LITTED UP BECAUSE YOU CONNECTED A COMPUTER WITH HELP OF ETHERNET CABLE.. IN THE SAME IT WILL WORK...
May 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Light problems
I wonder if your 'Active Wireless LAN' checkbox, found under 'Network > Wireless LAN > General Wireless LAN tab' is really checked. If so, and yet, your router doesn't broadcast, then I suppose its hardware is faulty.
Just my 2 cents... Carlos
May 17, 2010 | Zyxel P660HW-D1 Router
Wireless light on my belkin n- 150 router not
No Sync with the wireless, either may need to connect a wireless device or PC first... If now something to do with the wireless...
Mar 21, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
The only light on my router is the router light. No other lights are coming on. I have tried rebooting.
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Router will not go wireless. all lights come on
The "wireless" (second) light on this model does not indicate that the router's wireless features are active, it indicates that a computer is connected to the router wirelessly. If the "router" (fourth) light shows three little "radio wave" symbols, the router's wireless capability is on.
Nov 18, 2009 | Belkin (F5D8231-4) Wireless Router...
How can i turn the wireless on? the led for wireless is off?i cant find any switch except for the reset.
The wireless part of a router (AP = Access Point) is normally "switched" on or off by way of a setting in the routers configuration - check your owners manual on how to do this. There is no physical switch as such.
Also, the wireless light only lights when a wireless device has established a wireless connection to the AP. Even though the AP maybe enabled and working, until a wireless device connects, the light remains unlit.
I dont know this exact model of router so cant give specifics on how to set it up, but hopefully if you can find your manual, this gives you a starting point.
Oct 31, 2009 | Creative Labs Network Blaster Router
Wireless router signal not lighting
if the router has a reset button at the back press it for 10 seconds then turn it off and then turn it back on - will reset the route rto factory defaults and may fix the wireless light to comeon
May 09, 2009 | Dell (tmbun2) Wireless Router
I have a 2wire router from AT&T, all lights are green, except the "wireless" light. It's not on, how do I become wireless?????
Hi dilex
The 2wire router wireless light comes only when a system is connected to it wireless.
Please post the system that you are using and also what exactly when you try to connect via wireless.
Thank you
Rakesh
Dell Laptop Expert
Jan 06, 2009 | 2wire 2700HG-B Router (2700HGB)
I cannot keep my connection to my wireless modem/router.
the router may be bad i would take it back and exchange it
Dec 27, 2008 | 2wire 2700HG-B Router (2700HGB)
Belkin (F5D7230-4) Router (587009) Logo
190 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
