Question about Stanton C314 Tabletop CD and Mp3 Player
A year ago I bought a Stanton C.324 and now I have a big problem: The player suddenly stops and repeats short segments on currently track. I realized that the ANTI SHOCK AN BUFFER INICATOR is empty and The Bucket is flashing and flashing, so, i can´t play anything. This happens playing audio CD and mp3 CD too. What can I do to solve this problem?? Thanks.
  • willydonzag Jul 15, 2012
    Hello, I have exactly the same problem, have you found a solution?
    hello
    I've exactly the same problem. Have you found a solution?
    Thx
  • Stanton Master
  • 5,603 Answers
Dust and dirt could cause this by getting in the gear rack that moves the read head.
Make sure no one has smoked cigarettes around this as that is devastating to the optics in the unit.
An internal cleaning is probably in order and there are very fragile elements within the unit. I would recommend taking it to a shop specializing in CD repairs unless you are really capable.
I assume you have verified that the power is good to the unit.
Posted on Feb 03, 2010
Where do i take my stanton c324 to get repaired
I repair them. Email me for more assistance. Fennellcody@gmail.com
Jul 24, 2014 | Stanton C.324- Cdj C 324 C324cdj C324...
Hi, I have a boss BR 600 and when i insert any card it checks the card and then says ' card not supported'. I t used o work fine. However i have noticed that 2 pins seem to be missing inside t
I have the exact same problem. All my flash cards worked fine, and all of the sudden, none work. Not even the one that came with it. I am still trying to fine the reason. I bought it eight years ago, that might be it.
Jan 30, 2013 | Roland BOSS BR 600 8 track portable...
Is there a reset button or a fuse on the stanton m 203 mixers ive lost power
Officially, there is no user servicable fuse, However- there is usually one in the wall wart, which you can check simply by using a voltmeter and sometimes there is one internally. soldered to a small powe buss type of board such as was the case wth an older version of that basic mixer I repaired a number of years ago..
If warranty is not an issue, open it up and check. Just make sure to get all the screws out as nothing needs to be forced apart to open it up- just lots of screws.
Dec 17, 2012 | Stanton M.303 3 Channel 10 Inch Dj Mixer
Boss br-600 unsupported card
Feb 12, 2012 | Roland BOSS BR 600 8 track portable...
It's brand new, and it won't read disc
Run a cleaner disc thru 'em. If that doesn't fix it-take it back.
Sep 21, 2011 | Stanton C.324- Cdj C 324 C324cdj C324...
STANTON C324 NO DISK \r\nTHIS FIX THE PROBLEM AND COST YOU $25 NO LIKE IN STANTON $320 ;) http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290406538324&ssPageName=STRK:MEWNX:IT
You need a new laser or laser mechanism. You can order one online no problem. The part number is: Sony KSS 213Q. make sure there is a Q at the end of it because sony makes a lot of different laser types and the one inside the Stanton C.324 is the Q. Yes the C.324 has Sony guts. You might also want to look into ordering a RF Signal Processor Chip. the part number is: CXA 2581N. Once again make sure the part number ends with a N. This part you might have a little more trouble finding online but it is possible. The laser mechanism you can find on Ebay for about 20$ to 30$ and if you order it from stanton magnetics it will run you about 200$. The signal processor I bought the other day from a Sony parts Dealer in my home town for 20$. Im having an Electronics Repair place do it for very cheap. If you send your stanton c.324 to stanton magnetics you will end up paying more than the turntable is worth brand new unless you have valid warranty still on it.
Hope I could help you with the problem. Cheers.
Jun 15, 2010 | Stanton C314 Tabletop CD and Mp3 Player
Some cd's wont load
Currently I have one that won't load or unload.
That problem is a slipping drive belt. It is a small square profile belt near the front left of the machine. There is not enough tension and the motor spins its pulley inside the belt. The mechanism it drives is the load and eject function.
Feb 23, 2010 | Stanton C314 Tabletop CD and Mp3 Player
My stanton c324 after i put a dics in it reads "no disc" what happend to it and how can i get it fixed?
Had same issue with mine, talking with retailer it seems to be a common problem. I am in New Zealand and have been waiting 2 months for parts to arrive. Something wrong with laser and servo. Good luck getting yours fixed.
Oct 28, 2009 | Stanton C314 Tabletop CD and Mp3 Player
NO Disc
The first step is to clean the lens of the player using a cotton swab and alcohol. If that failes to resolve the problem, it is likely that the optics are starting to fail and need to be replaced.
Please clean the lens and update this with the results.
Thanks,
Dan
Aug 11, 2009 | Stanton C314 Tabletop CD and Mp3 Player
Stanton C314 Tabletop CD and Mp3 Player Logo
365 people viewed this question
Top Stanton Music Experts
Michial Gueffroy
Oloyede Monsuru
sreenivask
sreenivask
Are you a Stanton Music Expert? Answer questions, earn points and help others
