Question about Hobart Dishwashers
Hobart dishwasher date code MR means what year?
What years is my hobart dishwasher from if the date code is MR
  • 13 Answers
SOURCE: rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
Posted on Nov 15, 2008
SOURCE: hobart amx/aux-s dishwasher "bof" error code
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
Posted on Mar 04, 2009
bigg t
  • 640 Answers
SOURCE: i just bought a 16 year old hobart dishwasher ,i
what is the line voltage?1 or 3 phased?
Posted on Apr 17, 2009
SOURCE: what is p3 code on hobart am15 dishwasher
Our AM15 Hobart dishwasher is showing the wrench symbol. Past answers suggested repalcing the thermistor. I did that. Then I did a hard reset on the dishwasher, but the wrench symbol is still there. The water is only getting to 160 not 180. Now what?
Posted on Nov 13, 2009
  • 44 Answers
SOURCE: I have a PD code
PD is not an error code. It shows that when it draining water out shortly after power-up and when shutting down. If it seems to be showing "PD" longer than usual, it means the dishwasher's control circuitry believes there is still water in the tank, due to a faulty water level probe, most like the one under the lift-out screen. It has a plastic body with a metal probe coming out the center.
There is also a dual probe at the rear of the machine, but I believe the dishwasher uses the front probe to determine when to stop draining the machine during "PD" - most likely meaning "Power Drain" or "Power Draining".
If you are not seeing any E- codes (E1, E2, E3, etc.) then these water level probes are likely just fine and the "PD" is appearing normally, as it should during draining conditions.
Posted on Feb 23, 2011
What is the lifespan of a Hobart dishwasher
Most appliances have a design life of 10 years + or -.
Feb 28, 2018 | Hobart Dishwashers
Hobart glass wash machine amx-gh continue washing does not advance to the rinse cycle with no error code
only a suggestion is it heating up what i remember it want move on until it heats up to it's working temperature, good luck
Sep 22, 2016 | Hobart Dishwashers
Manufacture date hobart LX30 H. Serial 23-1044-007. ML 111 4354
If it is before Kitchen-Aid got involved, it is from the era before the 1986 buy-out by Whirlpool, so it is 30 years old at minimum!
Jul 12, 2016 | Hobart Dishwashers
Hobart AM15T ML-130039 with p2 message, what does this code mean
p2 would mean your rinse thermistor is open or shorted. its located on top near the the right side, after the vac. brkr. part# is 328994. remove old, istall new . dont forget to vote,hope this helps , monomoy
Jan 29, 2010 | Hobart 29 in. AM15-1 Free-Standing...
Need motor & impellor for Hobart AM8
I havn't seen an AM8 in over 15 years.
Hobart will keep parts available for quite a few years past end of production, but this may be too long. The AM 10 and early 12's are compatable.
You need a 6 bolt pump to motor. Yours has the old cast iron wash arms. All the new have light stainless arms. Just checked my records. the new AM12 which superceeded your design was in 1981. Perhaps look around for a used AM14 which fits your tables and plumbing. Confirm the voltage is compatable.
The AM15 is the current spec and is far superior.
Jan 09, 2009 | Hobart AM14-253 Free-standing Dishwasher
What is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
Jan 08, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Year manufactored
If you call your nearest Hobart Parts place they can tell you. If they refuse this simple request, log on to www.hobartservice.com and look in the discontinued products menu, select Food Machines then Mixers and sift through the files until you find the documentation for serial numbers/dates. The lists are not complete and stop in the late 1980's. If you're lucky, you can find out which plant manufactured it, as the first two digits of the serial number indicate where it was built. The serial numbers are not in code, so it's relatively easy to get a date if you do the math. While you're there, download the manuals for parts and operation. You won't find the service manuals..."Top Secret"! Good Luck! Ricardok45.
Dec 21, 2008 | Hobart N50 Stand Mixer
Hobart dishwaser
hi,i just read your issue.im a hobart service tech and fix these units all the time.what model do you have and are you sure the error is bof?let me know,i can tell you all the info,error codes about hobart dishwashers.
Jan 14, 2008 | Dishwashers
Dishwashers Logo
717 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
