Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
Monitor went Blank / Black (MAG Inov...lt916s)
Replaced capacitors witth ones of same ratings / voltages !
Picture came back on for 1 minute then quit again! replaced capacitor but now will not power up at all?
Any suggestions ?
obrigman@nc.rr.com
  • Oscar Brigman
    Oscar Brigman Feb 20, 2008
    Thanks for the information kishkane. Will try your solution this weekend and post results, having to pull double shifts at work so Saturday will be the when I can get to it, but that does sound like it could be the problem ! Again thenks and I'll let you know!
  • Oscar Brigman
    Oscar Brigman Feb 22, 2008
    Replaced all 470mf caps still "No Joy" !
    Question: There is a very large Capacitor rating 400V that has brown stuff on its side where it was folded down onto the board!
    Is this some type of adhesive or has this capacitor blown!
    Might sound like a really stupid question , but never took electronics courses just learned a few things from my best friends dad when we were teenagers, but back then the Whisper Writer was the latest thing and a company called Atarii came out with a little game called PONG!!
    Thanks in advance for any advice, especially whether I should replace this 400V capacitor !
I had to replace the inverter's capacitors as well. Started working right away - smoothly. Note: the old caps didn't leak or had any other visible defect - replaced them anyway.
Posted on Feb 21, 2008
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
MAG Innovision 900w flat screen... how to?
This is a common problem due to capacitors in the inverter circuit going bad. The inverter provides the voltage to light the backlight, so the lamp is usually not the problem.
If you open the case on the monitor (sometimes that's a challenge all by itself) and follow the wires from the backlight to the circuit board, you'll find the inverter circuit. There are normally a couple of transformers (they may be small square cases or round coils of wire on black or gray forms), some transistors, and the infamous capacitors. The caps are small cylinders with printed values on them, like 4.7uf, and also a voltage rating. Most of these are values you can find at Radio Shack, so if you or someone you know has soldering experience, you can try changing them. Stick with the original capacitance value (the uf number), but try to get a slightly higher voltage rating if you can. The voltage ratings come in standard values, like 16 volts, 25 volts, etc. The higher voltage parts will be a little bigger but should still fit. They go bad because the rating wasn't high enough to begin with. But it saves the manufacturer a little money on each unit. Make sure you observe the polarity of the capacitor (plus and minus, with some kind of marking on the circuit board to show you) when you put in the new ones.
Oct 05, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag LT916S Blank screen after start up
How do you know that your LCD is the real root cause of this issue? I suggest you try to use a KNOWN GOOD MOnitor/LCD to confirm it first.
Sep 18, 2007 | Mag Innovision 19" LCD Flat-Panel Monitor...
Power is on but no picture!
Hi...there,
It's seems you guys had a bad lucks! Your backlight inverter are busted. Need to replaced a new inverter...Guys! Have a nice day!
Sep 27, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag 19" LT916s
Jun 08, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
The monitor with no picture
There are few possible reason that the screen doesn't comes properly. You should check these things carefully 1. Make sure the capacitor chipset is good . 2. Soldering need to be perfect ( because if you put more than it needed then sometimes it make problems). 3. Check the LCD paper displaced or not.
May 27, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag 17" goes black, changing capacitors but 4 are 1000uf instead of 470.
Replace the caps with the correct picofarad ratings. IE if you take out a 470, then put a 470 back in. Also note the voltage on them. You can go higher, but do not go lower. So if they are 470 16v (16 volts), then you can use 470 25v (25volts) etc. Just don't get them mixed up.
Best option is to replace all of one rating, then all of the other. Also note the stripe on the side of the capacitor. This indicates negative and should match up to a circle printed on the board (probably hidden under the current capacitors) with a light side and a dark side. The negative (stripe) on the capacitor goes to the dark side of the circle.
The burn marks are quite common. It's from heat being transferred through the PCB to dissipate it.
If you are unsure about any of this then just post back here.
Apr 04, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MAG Innovision LT916S monitor problem
Hi this is the way how to examine what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Mar 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MONITOR MAG LT916S
Good Luck!
Feb 12, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor goes black but green light still on.
The problem with the Mag lt916s is that it is made with cheap capacitors. If you are interesnted it is a cheap and easy fix. Open it up, which is the hardest part. And replace the six 470uf 105 degree 25v capacitors and maybe even the smaller 220uf one next to them. You will see a bump on the top of bad capacitors most of the time. There are some videos to watch on Youtube showing you how to make the repair.
Good luck
Dec 27, 2007 | Computers & Internet
Monitor blacks out after length of use
Well, first of all. Do not open it if you do not have any knowledge of what you are doing. Because it will probably make it worse. Second, trying different monitor cables will not help either. I had the exact same problem, and I tried everything possible. After a while it stopped working all together. Showed the screen for one second and blacked out after that. No matter how long I let it be turned off. You should probably hand it in to a repair shop or buy a new one. I did the same thing myself and ended up buying a new one. You could also let the monitor stay on, the next time and never shut it off :P.
Apr 10, 2007 | Mag Innovision 19" LCD Flat-Panel Monitor...
Computers & Internet Logo
173 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
