Question about Sony STR-DE325 Receiver
My kenwood receiver is on but no sound
There is alittle sound barly here it and muffeled read bad cant make out anything
  • 336 Answers
Check that the tape monitor (or tape 2) is not on. To turn it off press the tape 2/tape monitor button. Turn the volume down first!
Posted on Feb 02, 2010
Kenwood DP5010 CD player motor doesn't working but i tested the motor, the motor is ok.,how do i fixed it?
the laser gives the signal for the motor to spin check the laser..clean and test...also on the laser is a pc board wit alittle screw adjustment for the laser
Jun 20, 2016 | Kenwood Car Audio & Video
Losing my high
it can be fixed. try to check all the connections.
Sep 25, 2008 | Kenwood KDC-MP435U CD Player
USB port no longer working
USB port get damaged. I have 2 bad USB ports in my computer. so I installed a new USB 3.0 card.
In a car, probably you should know more about the technics but all you can do is replace bad USB port. No way out.
Jun 14, 2015 | Kenwood KDC-MP438U Car CD/ MP3 Player
I need help trying to set up the surround sound for my vr-390 receiver. i have two two large side speakers. a large middle. and a subwoofer i cant get to work. (all kenwood) i also have 2 bose surround...
Manuals help. Read them. Nothing in your receiver is actually a multichannel source so you'll be needing to understand the external sources that originate that kind of programming. Manuals.
Here's one...
http://www.retrevo.com/support/Kenwood-VR-309-Receivers-manual/id/480dj195/t/2/
Try the other manufacturers' support sites for your unidentified gear, by using a common search engine or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
'Large' is not literal in the context of Bass Management. It refers to the ability of a given speaker to handle REAL bass. Yes = Large, No = Small. 'Small' redirects bass from that speaker channel to the sub.
Web search concepts like bass management, speaker placement, multichannel sound, digital audio, etc.
Sep 05, 2011 | Kenwood VR-309
Hi i have a Kenwood Audio-Video Receiver KR-V6090 and when i turn it on all the speakers are plugged in and the speaker light at the front on dim after a couple of seconds the is full on and i cant here...
HAVE U TURNED THE SPEAKERS ON BY PRESSING THE BUTTON FOR THE SPEAKERS. ARE U USING SURROUND? IF NOT THEN U NEED TO MAKE SURE U HAVE THE RIGHT BUTTONS ON OTHERWISE U WILL GET NO SOUND HAVE A PLAY ABOUT WITH IT AND SEE WHAT U CAN DO. I HAD THE SAME PROBLEM WITH MINE AND I GOT IT TO WORK AFTER .
Apr 17, 2010 | Kenwood Audio Players & Recorders
How do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dan
Dec 27, 2009 | Kenwood VR-405 Receiver
Kenwood VR-507 Now only get sound from 1 front speaker. all other speakers have stopped. Have not changed anything.
PROCESS OF ELIMINATION: connect each of the other speaker in the working to check to see if the wires and other speakers are working. If all speaker play when connected to the working channel check all other cables and connections....use the tuner as an working source to test. If that doesn't help then you may have an bad channel in your amp and may need to be repaired.
Oct 31, 2009 | Kenwood VR-507 Receiver
Display Problems Kenwood
the problem is more than likely bad solder connections on the surface mount resistors located on the right front of the deck itself.
Sep 17, 2009 | Kenwood KDC-W5534U CD Player
1992 ford ranger pickup 4 cyl. 5 speed
Your engine coolant temp. sensor is going bad. What happens is that your engine computer is receiving a bad signal from the ECT sensor and it thinks it's 40 below. An example is it basically slams the choke shut if it had a distributor. When it cools off, I'll bet it runs just fine.
Jul 24, 2008 | 1992 Ford Ranger
Kenwood kdc-mp528
it sounds like the laser is bad, here is the part number
X93-2010-00
You can probable buy it from an authorized kenwood service center
Jan 20, 2008 | Kenwood KDC-MP528 CD Player
Sony STR-DE325 Receiver Logo
103 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
