Question about AT&T Computers & Internet
My modem makes a high pitched squeal. Does it
My modem makes a high pitched squeal. Does it need replacing?
SOURCE: high-pitched sound when using surround sound
THANK YOU Guest (4/10/08)!!!
That was exactly what I needed! We have had our system for 4.5 years and suddenly, the FM feedback on everything, but DVD and Radio! Your fix helped. Once I set all my presets (at least the current one) to a clear station, the feedback stopped. Hallelujah!! We can enjoy this piece of junk once again! ;)
Amanda - San Antonio, TX
Posted on Oct 11, 2008
  • 740 Answers
SOURCE: Squealing noise in 2002 Nissan Sentra
Seems like a drive belt problem, to confirm pour some water on belts the noise should go away or may get louder for a second. If either happens the belt or belts needs to be adjusted or replaced. Good Luck, If I fixed ya, leave me a FIX-YA comment thanks
Posted on Dec 18, 2008
SOURCE: MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
Posted on May 12, 2009
  • 5 Answers
SOURCE: High pitched squeal
sounds like the water pump bearing might be defective. best advice is to replace the pump.
Posted on Jun 09, 2009
  • 3 Answers
SOURCE: high pitched squealing noise when i start engine
One of the belt should be loose or worn. Make sure they are not worn or cracking before tightening.
Posted on Jun 23, 2009
Blower fan makes a high pitch squeal.Replaced fan but squeal is still there.
'high pitched squeal' sounds like the serpentine belt on the water pump, not the heater fan.
Dec 17, 2015 | 2011 Hyundai Tucson
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
HIGH PITCHED dryer SQUEAL but clothes are drying...
Had same problem that went away after replacing each of the drum roller wheel/bearing assemblies. (repairclinic.com) Not the easiest of jobs removing & replacing the drum, but a lot cheaper than a new machine.
Nov 23, 2013 | Frigidaire Washing Machines
2004 trailblazer ext high beam headlights wont turn off and the relay makes high pitched noise
Need to check the ground path on the squealing relay. A poor ground will cause this condition.
Feb 27, 2013 | 2004 Chevrolet Chevrolet TrailBlazer EXT
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
High pitched squealing noise when i start engine
have Your alternator belt checked for the propper tension:]
Jun 17, 2009 | 2003 Nissan Frontier Crew Cab
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
Computers & Internet Logo
62 people viewed this question
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
