Question about Kenmore Refrigerators
Kenmore 52552100 Side by Side ice in bottom of freezer
I have a Kenmore 52552100 Side by Side fridge / freezer and there is ice forming in the bottom of the freezer. Eventually water leaks out onto the floor I think maybe when it defrosts. If you remove the ice from the freezer it comes back in a few days.
Anyone have any advice?
I had the same problem. And after some research I went at it yesterday. I unplugged the refrigerator and removed the bottom two racks in the freezer. The tray at the bottom of the defrost assembly was caked with ice. I didn't know where the drain plug was. I started melting the ice using a hair dryer. I also carefully broke up the ice using a knife. After the ice was removed I could locate the drain hole. I used a copper wire shaped like an "L" and tried chipping away at it with no luck. I then poured a 1/3 of a cup of very hot water in the tray and let it sit. After a few minutes I used the hair drier again and soaked up the water with a paper towel. I added another 1/3 cup of hot water. I noticed the ice in the drain hole was beginning to melt and used the wire again. Finally, I got my compressed air gun and blew out the hole. I wanted to just blow the water out of there but it must have shot the ice out into the evaporator tray. I poured more hot water in the tray and it disappeared immediately into the evaporator tray (checked the tray and could see water). I then blew out the hole with compressed air and dried the area with the hair drier. Plugged in the refrigerator, replaced the baskets and was done. Whole thing took 30-45 minutes. No idea why it clogged up in the first place but if it happens again I should be able to cut 10 minutes off the time.
Posted on Mar 23, 2010
Freezer over freezing too much ice at the bottom and fridge side not as cold.Kenmore side by side
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Jul 07, 2011 | Kenmore Side by Side Refrigerator
My refrigerator is a side by side kenmore and the freezer over freezes and too much ice build up at the bottom and some tomes the refrigerator side is not as cold as it should be.
Since the fridge has cooling the compressor /gas pressure is good.It is possible that the frost has blocked the cool air flow from the freezer to the fridge area.
To confirm shut off the fridge, Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
So try this test from the outside and make your observations so that we come to the solution. The defrost timer is located at the bottom, check the connections to the heaters and the thermostat.
Jul 07, 2011 | Refrigerators
The freezer is forming ice on back wall and all around the ice bins where the ice storage is, plus forming on food boxes, what could be the problem?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Kenmore TRIO 77314 Side by Side Bottom...
Ice forming on the back of side by side 17 yr old fridge
You have a bad defrost heater . To access , you will have to remove the inside rear freezer panel . The heater is located at the bottom of the coils . Take your model number when ordering the part so you get the correct part .
May 02, 2010 | GE Refrigerators
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Freezer door on GE side by side stays open slightly at top
i have kenmore side by side model 52552100 and the ice maker will not send ice thru the door. I is not even making any sounds when I push the button dispense. Can you duplicate this problem
Apr 10, 2009 | GE GSH25JFR Side by Side Refrigerator
Water freezing up in the bottom of the freezer
your defrost drain is stopped up then when it defrosts in steed og going down the drain its running in the freezer floor remove the back panel in the bottom of the freezer and clear the drain hole under the evaporator
Mar 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Top Freezer working, Bottom Fridg not.
ice block has formed in the air exchange from the freezer to fridge. Turn off and thaw out, afterwards, check to see if the fan motor is running unobstructed. If problem persists, replace fan motor with new
Aug 10, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
243 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
