Question about Amana DLE330RAW Electric Dryer
Dryer element is ok but dryer will not get hot.
    Scholar:
  • 111 Answers
Normally in these there is a thermostatthat is non resettable. It may be a small round on close to the coils or a plastic (white) with two terminals located inside the controls area. More than likely one has blown and now does not allow current to go to the heaters. This may have happened if your vent was stopped up.
Posted on Feb 01, 2010
My Whirlpool duet sport dryer got hot and shut off after running 20 minutes.
Sounds like you may have a bad heating element that has grounded. You should have this looked at to make sure if you aren ot handy to open the dryer up and inspect the heating element your self. make sure the element wire has not broken and fused itself to metal inside the dryer heater housing.
Feb 02, 2017 | Whirlpool Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
Sep 28, 2012 | Fisher and Paykel Dryers
Wont get hot and dry clothes
If the dryer runs the same as before except it will not get hot then check your heating element that is more than likely your problem.
Sep 04, 2012 | Maytag MDG6400 Atlantis Gas Dryer
Dryer will not get hot. All the vents are clean.
Check for burnt out heating element and electrical connections to element and thermostats. If okay check all thermostats, operating and high limit, with an ohm meter. All must be in closed position. If element,thermostats,and electrical connections good then check timer.
Mar 21, 2010 | Whirlpool LER4634J Electric Dryer
Our kenmore dryer wont get hot at all and it wont dry our clothes
SOUNDS LIKE YOUR HEATING ELEMENTS HAVE BURNT OUT AND YOU NEED TO REPLACE THEM.
Oct 23, 2009 | Kenmore 63942 Dryer
Dryer gets hot then stops mid cycle
hi
is the heating element and motor belt is ok,,check that
,,,,,,,thank u
Mar 07, 2009 | Whirlpool LEB6200 Electric Dryer
Dryer not getting hot want get hot, heating element ok what else do i replace
Check and see if this dryer has an electric ignitor switch. if so then this would be your best source of the problem.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Amana DLE330RAW Electric Dryer Logo
96 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
