Question about The Times Case Corporation Tractors International Harvestor
Diesel tractor ran out of fuel now it won't start
Diesel tractor ran out of fuel, after refueling tractor (case 188D) still won't start
    New Friend:
  • 161 Answers
Agree with with previous answer.
Check your fuel filter & make sure it's full of fuel,
usually the problem if the motor wont start after
running it out of fuel.
Posted on Jan 26, 2013
    Champion:
  • 435 Answers
You have to take the air lock from the fueling system.
Posted on Mar 04, 2010
Restart after refuelling the tank?
what fuel is it as it can be air in a diesel so you have to bleed it. or you have damaged your fuel pump in a gas car in the uk we call that a petrol car .you pump needs fuel to cool it.
Mar 03, 2015 | Cars & Trucks
Why wont my leyland daf 45 Horsebox start after it ran out of diesel then was refueled
you have to vent the air in the injection pump crack the injector pipes and crank the engine till fuel come out then re secure the pipes it will start then
Jul 28, 2014 | 1970 DAF 44
Stiga park lawnmower
Are you certain it is a fuel problem and not electrical? Remove fuel line right before it enters carburetor, turn mower over and see if fuel is pumping out. If not, check for any foreign material in fuel tank where fuel exits the tank to the fuel line. You can do this by blowing pressured air into fuel tank and observe if fuel is coming out of end of fuel line. Check for clogged fuel filter.
Jun 08, 2013 | Garden
Ran out of diesel now vehicle won't start
This is not unusual on a diesel. What happens is there is air in the system. If this vehicle has an electric fuel pump loosen line where fuel enters injection pump then turn ignition key to the on position and watch for fuel to appear and then quickly tighten line before turning off key. Then try to start. If does not have electric fuel pump will need a second person. One will loosen line and watch while other cranks vehicle until you get fuel and tighten line before the other person releases ignition switch unless vehicle starts first. If that doesn't do the job do this where line hooks onto each injector. Probably will not have to do this to all injectors but could run rough until all the air gets out of everything. I have farmed with diesel tractor for 25 years and dad I drove the gm vehicles with the 5.7. You normally don't start a diesel without bleeding the air out of the lines although some will self bleed most won't. Hope this does the trick.
Jun 21, 2012 | 2004 GMC Sierra 2500
John Deere Diesel X495 garden tractor running VERY rough.
Bleed the lines while the unit is running making sure you get all the air out of the lines.
May 06, 2012 | Diesel Garden
Ran out of diesel 1.9 TDi 74kw. have refuelled and cranked engine for 15mins and still it won't start. there is fuel from tank to filter, to pump and return flow.
This is very important for Audi 1.9 TDI engine: IT IS FORBIDDEN TO RUN WITHOUT DIESEL FUEL IN RESERVOIR !!!
This type of engine is equipped with pump-nozzle injectors which develop up to 2050 bar injection pressure !
Remove the fuel filter, fill up with diesel fuel and put in place. After that try to start the engine with accelerator pedal to the floor. Heed of electric starter motor temperature and battery status! After 40 - 50 sec. of start attempting wait for 1 - 2 minutes for battery and electric starter motor revival. After few starting attemptions the engine must start.
Jan 13, 2010 | 2004 Audi A4
Ran out of fuel just as tractor came to a stop in the yard. Have tried to bleed lines but pump lever doesn't seem to make any difference or have any resistance behind it. What do you think?
When a diesel runs out of fuel ... my friend ... it takes a lot of effort to get the air out of the lines. Keep doing what you are doing ... keep grinding on the battery ... don't kill it or the starter ... and, as my daddy told me, 'let this be a lesson to you ... don't let your diesel run out of fuel!'
I'm sorry you ran out of fuel ... it will rujn again.
Dec 24, 2009 | Diesel Case 1370,1470,1570 Tractor Piston...
The Times Case Corporation Tractors International Harvestor Logo
1,337 people viewed this question
Top The Times Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a The Times Toy Expert? Answer questions, earn points and help others
