Question about Sony Computers & Internet
My laptop vajo stop working at first it said that it was checking disk and then it said something about disk error so what can i do
Your hardisk cannot be detected, something wrong with it. or no operating system installed in your laptop that's why you got a disk error.
Posted on Feb 01, 2010
I was using my laptop suddenly screen goes off anad then i restart my laptop it's turn on but stop at first page with no clue or something show it,s on but with black screen, is it hardware problem?
first re seat your ram and check if not, disconnect your hard disk and power on, after the computer powers on you should get an error saying that your hard disk is missing or check bootable media. this should happen fast after disconnecting the hard disk. and if this is so, then it'll be that your hard disk is failing.
Apr 10, 2016 | Computers & Internet
Compac windows 8 , run scrpt errors on page, slow hangs
I woud run a registry cleaning programme. It sound like you have registry errors.
Dec 02, 2013 | Compaq Computers & Internet
Error message stop 0x00000024
which operating system ?
If you get the Windows blue screen, you can determine which stop code you have and determine what you need to do in order to get your computer back to working correctly.
First, make sure that you have this error code - Stop 0x00000024 or NTFS_FILE_SYSTEM. This message shows that a problem occurred within Ntfs.sys, the driver file that allows the system to read and write to NTFS file system drives. One possible problem is a malfunctioning SCSI and Advanced Technology Attachment (ATA) hardware or drivers. This can also adversely affect the system's ability to read and write to disk, causing errors. If the computer is using a SCSI hard drive, check both for cabling and termination problems between the SCSI controller and the disks. You will need to periodically check the Event Viewer for error messages related to SCSI or FASTFAT in the System log. You can also use Autochk in the Application log. Try the following. First, Double-click My Computer, select the hard disk you want to check. Then, on the File menu, click Properties. Then, click the Tools tab. Next, in the Error-checking box, click Check Now.
Finally, in Check disk options, select the scan for and attempt recovery of bad sectors check box. You can also select the Automatically fix file system errors check box.
http://answers.microsoft.com/en-us/windows/forum/windows_xp-system/windows-xp-blue-screen-error-message-0x00000024/9d6475ed-dc42-4fa7-a2a2-506c42f6ee63
Feb 24, 2013 | Computers & Internet
MY Laptop Is Very Slow And Crash
* check you virtual memory or adjust it...
* scan your laptop with the latest update of anti-virus,might your laptop got many viruses.
hope this solution helps..... please rate my performance... thanks
Jun 02, 2011 | Sony VAIO VGNNW330FW 155Inch Laptop White...
My laptop computer is running slow? how can get rid of junks stuff on the laptop?
Your friend is a program called CCleaner. Run it, rerun it, do whatever you need. It's heavenly.
http://download.cnet.com/ccleaner/
May 24, 2011 | Computers & Internet
Sir, hard disk is not partioned. so,you may give some idea.
Hello
Many laptops does not work as Pc desktops thats why sometimes we need the branded Cd Disk to perform All installation steps using that Cds only (Branded)
If tried with other CDs the Laptop may stop working and error may arise so make sure you are using the branded Cds and perform needed installation if Hard disk does not get partitioned after using the branded Cds then check for the Hard disk slave and master option and Cmos setuputility
you can remove the hard disk and use other system o partition it
this may fix your problem
Feb 08, 2011 | Computers & Internet
Hi, I have a Toshiba 80GB MK8037GSX 2.5" SATA in
1) have checked bios cannot see hdd mounted.
That is BAD -- the disk-drive could have "died".
2) tried a seagate hdd works fine so connections in laptop seem to be working
That shows that your motherboard is GOOD, but that your disk-drive is BAD.
3) can hear hardrive trying to do something as can hear harddrive usual noise, continous noise for about 5 sec before getting the error message
That is BAD -- the disk-drive is "dying".
4) no rattling or crackling noise from drive apart from the above
That is BAD -- none of the files can be read from your disk.
i have created a ubuntu boot up disk which allows me to access laptop but does shows error when locating hdd,
That is BAD.
once in ubuntu i can access internet but it does not show the windows partition of the harddrive, only shows ubuntu as opearing system, confused.
That is BAD. Only the CD/DVD disk has been mounted -- Ubuntu could not mount the disk-drive.
In regards to ubuntu working does this mean the hdd is ok?
No, it means that your motherboard is working.
and is there anyhting i can try via ubuntu to locate the files?
No. The disk-drive is "dead".
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 13, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
Laptop start up error
This error comes when there is memory issue .
Harddisk issue or RAM issue.
For that if you have windows recovery disk you need to run disk checking program
Most of this error comes becuase of hardddisk error.
Boot your computer with windows xp disk then enter in recovery console mode then type in prompt "chkdsk /r"
then press "y"
then it checks disk andf fix error if found any error on harddisk.
then you can boot your windows.
Thanks for using fixya.
Please rate my solution if it hleps.
Pls let me know if you need more assistanse.
Many Thanks .
Jul 24, 2009 | Acer Aspire 4315-2963 Notebook
Wd external hard disk and lenovo s10 notebook problem
this is due to virus or malware. it is possible that it is present in hard disk. whenever you tries to open the file, at that time the virus get activated and creats error.........for this you need to install the latest updated antivirus. but some antivirus are worthless. so i recommend you to use quickheal antivirus and scan the hard disk
Jun 20, 2009 | Western Digital Passport 320GB External...
Laptop freezes
This can be caused by system file error or your CPU is over heated. I suggest you to have a system check first To check and repair system file error do the following
Right Click on the system disk (c: drive) then Properties > Tools > Errors checking Check now > Tick on "Automatically fix file system error
It will prompt you to schedule the check next time you restart. click YES then restart and let the system have the checking
If this doesnt fix please tell me
Best regards
Dec 05, 2008 | Acer Aspire 5920-6727 Notebook
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
