Question about Sony RDR-VX530 DVD Recorder/VCR
Im trying hook up my dvd player i have the sound but the picture wont show and i put it on every channel
  • Sony Master
  • 12,061 Answers
Try using the Yellow, Red & White Jacks to the TV, wire color to color.
Posted on Feb 01, 2010
I have a Toshiba dvd player and all the componeyd are hooked up,right but the,screen for the dvd channel is white with lines and wont show the picture movie what's wrong
You may be using the wrong channel. Is the input the 5-plug component or the 3-plug RCA?
each one will use a different channel, and component will not work in rca and vice-versa.
May 03, 2011 | Westinghouse Televison & Video
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Just moved, hooked up DVD player to new TV. Sound
if you have a picture on the tv from normal channels and/or cable, then i would suspect the scart lead may have a bent pin at one end or both or is not inserted fully.
Feb 20, 2010 | GPX D1816 DVD Player
Im trying to hook up my new lcd tv using a cable box and a dvd player but cant find any diagrams. As of now I can get a picture but the sound is low and can only be turned up by the cable remote. Any help...
it should not be a big deal red and white is sound yellow is video, if you have a converter box and are not getting a signal I would suggest you try moving your antene to get picture. Try hooking the DVD plaer into the TV to AUX 1 or AV1 or AV 2 Or AV3 and make sure the TV is on the right channel on to see Picture and correct level of sound, are you running anything threw a coverter box? Need to know the TV brand to do a diagram. The output from the DVD player shoud go into AV1 and the wire colors should be the same DVD output to AV1 input or AV2 in?
Jul 06, 2009 | Televison & Video
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
My Sharp 42" LC42D85U tv 1 month old no picture or sound
i would take it in and have it repaired while its got a warranty on it...or take it back to the store you got it from and ask them to replace the set.
Feb 01, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Unable to get play dvd or get picture on DVD channell on tv
If the player is doing that for all DVDs but playing CDs properly, the player has gone bad due to either the laser and lens being out of whack or the DVD drive just doesn't recognise DVDs anymore and needs repaired or replaced.
Sorry. Best of luck.
Jan 01, 2009 | Philips Televison & Video
When i hook my dvd player up i don't get a picture, when i play the dvd, i get sound. what is wrong? thanks bonnie
If Progressive scan is turn on the player and not on the tv it wont show a picture, or it could be your tv doesn't have progressive can, or check your AV cables, if through componet you have to make sure your tv is on the componet channel and that the colors all match and are inserted fully into the jacks.
Dec 29, 2008 | Philips Magnavox MWD7006 DVD Player
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Picture of dvd wont play
just bought a new car with one of these dvd players. when i put a dvd in, the sound is working fine but the screen says it cant show the picture because the car is in motion
Mar 21, 2008 | Eclipse AVX5000 Car DVD Player
Sony RDR-VX530 DVD Recorder/VCR Logo
106 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
