Question about Acer Computers & Internet
Where is the apostrophe on my keyboard. Also, when I press the question mark key, this is what I get.....é. How do I get the question mark
To the right of the line with kl;. to the left of the enter button
Posted on Feb 01, 2010
Cannot change the function on my keyboard back to a question mark
If you're on Windows then try pressing CTRL+SHIFT keys together (sometimes ALT+SHIFT, see which combination works for you) until your keyboard layout indicator in your system's notification area (bottom right part of your screen, just left of system clock) shows the keyboard layout code that you're used to, in your case "EN". You can cycle through all the installed keyboard layouts using this same key combination.
Mar 02, 2012 | Compaq Keyboard
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
May 02, 2011 | Computers & Internet
When I strike the apostrophe, quotation marks (or double appostrophe)appear. When I Shift + apostrophe, double quotations appear. Same thing happens with the tilde key. So far just these 2 keys...
Sounds like a defective keyboard. I seen issues when pressing a button it will trigger another key to be pushed or nothign displays at all. Try replacing keyboard since they are relatively cheap. othersie maybe a software issue
Mar 03, 2011 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
HOW TO GET MY LAPTOP TO STOP USING THE PINK ALTCAR
I found this on another website and it worked for me. Good luck.
Okay, I know this is an old question but when i searched for the same problem recently, it was the nearest I could find. So in case others are having the same problem:
The Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. The alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
Sep 25, 2010 | Sony VAIO VGP-WKB1 Keyboard
Keyboard problems
Sounds like the wrong keyboard driver installed. Control Panel>Region>Keyboards & Language
Oct 04, 2009 | ASUS 90-A4C1K1000 Keyboard
Unable to type question mark i getÉ colon è
Nothing. You just need to change the keyboard layout. For help Start > Help and support > (type keyboard layout) and press enter.
Aug 25, 2009 | Toshiba Portege 3500 Tablet PC
Have an e-machine H6535 running Windows XP home edition 2002 service pack 3. Having trouble keyboarding certain keys. All letter characters and numbers appear up ok but the other keys produce variant...
your "NUM LOCK" is on, you need to find the key and press it, its usually near the top right hand side of the keyboard.
the problem should then be solved
regards
Nov 14, 2008 | Computers & Internet
Cannot get apostrophes or question marks
I just figured this out. Hold down your left shift key, then press CTRL. It may take a couple of times for it to work, but it will eventually.
Oct 08, 2008 | Compaq Keyboard
Computers & Internet Logo
847 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
