Question about Invicta Watches
I just bought an invicta 4906 Corduba Ibiza Diver. It has a "Techno Strap" what does that mean? is it ok do dive with it? I don't think it is leather but a synthetic of some kind. Thanks Dave
5 Suggested Answers
SOURCE: invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
Posted on Jun 16, 2008
VOTIT
  • 2071 Answers
SOURCE: how to remove links on invicta russian diver watch
Hi Pate the only thing i can advice you is go to a service center near to your place.All watch technician like me have the knowledge to remove the links with no impaired damage or scratch.We know how to detach the links.So if want to know more of your watch i will give you a site that can help you and ask more information about your watch. www.invictawatch.com
Posted on Jun 17, 2008
escapement
  • 2334 Answers
SOURCE: i have an invicta corduba diver watch how do i
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jan 09, 2010
mcdevito75
  • 1970 Answers
SOURCE: I own an Invicta Russan Diver Model #4578 and I
mcdevito75 here, I would contact shop NBC for info, here is their contact number, 800-474-6762 They should guide you to Invicta parts.
Posted on Aug 13, 2010
How to set?& manual required invicta.15343 pro dive
Invicta Pro Diver - View model
invictawatch.com/collections/view-model/15342-pro-diver
INVICTA COLLECTIONS click to view models · AKULA ... Instruction Manual Print. More models of the same style. 15343. Invicta Pro Diver · share watch. 15341.
Sep 25, 2015 | Watches
I have a Invicta 4504 and I cannot get it started. Please help
It'so possible that the new battery is defective. Are you sure the stem/winder is fully seated?
Dec 18, 2014 | Invicta Corduba Collection Retrograde...
Invicta watch instructions
Straps are usually held in place by two spring loaded metal pins between the two lugs on either side of the strap. Look at the ends near the lugs you should be able to see them, use a very small flate blade srewdriver to pull back on the pin and once you get it, it will pop out of the hole its in.
Aug 18, 2014 | Invicta 15997 Mens Venom Chronograph Blue...
Invicta corduba #4898. Crown will not pull out to adjust time and date. Large cap removed, smaller croen head will not come out. Is there a trick to it? Thanks, Steven
Divers watches usually have to have extra strong seals to prevent water getting in. This often achieved by screwing the crown wheel (to the right?) after it has been pushed home.
To pull the crown out, first rotate it anticlockwise about 1/4 of a turn and then pull.
Jun 16, 2011 | Invicta Corduba Ibiza Diver 4898 Watch for...
I own an Invicta Russan Diver Model #4578 and I nee replacement screws for the rubber strap. Do you know where I can find them ?
Aug 13, 2010 | Invicta Russian Diver Quinotaur Ccp...
The stem cover will not open, not sure why, and also not sure which end to exert unusal pressure, as nothing works now short of getting out a screwdriver and trying to pry it open. also, are the upper and...
mcdevito75 here, the stem may have a screw down cover if it"s been screwed down to tight you may not be getting a good enough grip to loosen it, Look for a small watch repair shop for this problem. Donot use ant tools yourself to loosen this screw down cover.
Jul 07, 2010 | Invicta Corduba Skeleton Techno Strap...
Does my 2010 invicta corduba have pins or screws in the braclet? how do I remove them? They look like screws but juts spin around both way when i turn them.
Sometimes the split ends of pins look like screws. If the slot is extremely thin its a pin A screw slot will be a bit wider. I pin removal toll inserted into the smaller end should do the trick.
Apr 30, 2010 | Invicta Corduba Skeleton Techno Strap...
Invicta pro diver strap length
Jun 10, 2008 | Invicta Pro Diver 9321 Wrist Watch
Watches Logo
120 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you an Invicta Watch Expert? Answer questions, earn points and help others
