Question about Kenmore 54501 Dehumidifier
Can you run it under 60o - Kenmore 54501 Dehumidifier
  • Kenmore Master
  • 43,501 Answers
Posted on Apr 30, 2010
I have a Frigidaire dehumidifer model FDL70S1 that wont stay running for more than 3 minutes and then it shuts the fan off, but still has power to the unit.
Hi lynn crisp, thanks for your post!
From my understanding you are having a challenging time with your Frigidaire dehumidifier shutting too quickly. It sounds like a possible problem with your sensor or control panel. Are you currently under warranty? I would contact your manufacturer for assistance to a proper resolution. -Matt
Oct 20, 2014 | Frigidaire Dehumidifiers
My model DDR6588EE dehumidifier runs for a while and then stops displaying an E1. If I hit power button it will run a while and do the same thing. This also happens on Continuous mode. Is there some thing...
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 25, 2009 | Danby DDR6588EE Dehumidifier
Unit runs but water collects on the floor
The drain hole within the unit is most likely plugged up with an accumulation of crud. (Common problem). Depending on the make/model, you may be able to access that drain hole by simply removing the collection bucket. If not, then unplug the unit and remove the housing to gain access to the internal drain.
Jun 19, 2009 | Goldstar DH304 Dehumidifier
Will run but won't take moisture out of the air
Fedders, the maker of the maytag dehumidifier, went bankrupt and they are not honoring the warranties. call this number and if it is still under warranty, they will send you a prorated check for the remainder of your warranty. 1-866-629-8241. we had two months to go on our warranty and they gave us $14 and change.
Jun 01, 2009 | Maytag M3DH30B2A Dehumidifier
M7DH45B2A dehumidifier does not have auto restart when power goes
No. I went away for a week and set mine up in the tub. Power went out and it was off when I got home. You could buy a UPS ( unterruptable power supply) from the computer area in Walmart and hook it up to it. This would allow it to still run for a while and if the power came back on while it was still under battery power it would run like it was running. You can buy larger UPS units that would keep it running for longer amounts of time. Just an idea.
Jan 03, 2009 | Maytag M7DH45B2A Dehumidifier
Dehumidifier won't shut off
Well your dehumidifer runs constantly. My guess seeing how you bought a 30 pint per 24 hrs. Your house better be 400sqft. It is under sized and humidity need to be 30/50 percent to stop mold growth. It cant keep up its two small 50 pint are for 1000sqft 65 pint is 1300sqft. Upgrade now!!!!!
Dec 29, 2008 | LG DH30 GoldStar Dehumidifier
Gold stare dehumidifer
It sounds like there is an issue with the controller board. LG has a 5 year warranty on these models. You may want to contact them first instead of opening it up because it could void the warranty. My recommendation is to have this serviced if it is under warranty. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
Jul 20, 2008 | LG Goldstar LD65EL Dehumidifier
The condensing unit does not run consistently, it clicks on every minute or so.
It sounds like there is an issue with either the controller board or humidity sensor. LG has a 5 year warranty on these models. You may want to contact them first instead of opening it up because it could void the warranty. My recommendation is to have this serviced if it is under warranty. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
Sep 13, 2006 | LG Goldstar LD65EL Dehumidifier
Kenmore 54501 Dehumidifier Logo
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
