Check the power cable first. Check your monitor switch is working properly or check your smps in your monitor.
Comments:
Feb 19, 2008
- If you known electronics means you do this because its dangerous . You want to remove the monitor cover. And then check the supply coming or not through the multimeter.
my monitor has squiggly vertical lines. Turned off this a.m. Turned back on this evening. Don't look...
(More)
my monitor has squiggly vertical lines. Turned off this a.m. Turned back on this evening. Don't look good! Is is time for a new one? Also, when i boot up it is telling me to insert boot disk! I turn it off and turn it back on and it will load. What is going on?
hi the lcd screen sometimes goes crazy with lines and odd colors and all that looks like a bad...
(More)
hi the lcd screen sometimes goes crazy with lines and odd colors and all that looks like a bad connection but ll the wires are hooked up fine and if u lightly smack the front of the screen it goes back to normal is there anyway to fix this without buying a need monitor. thank you
my monitor did the same thin, just went blank, after turning it off and reattaching everything it...
(More)
my monitor did the same thin, just went blank, after turning it off and reattaching everything it worked for a couple of hours the quit - permantly - i found a site http://boredprojects.blogspot.com/2008/06/hp-vs19d-fix.html went to radioshack and got 3 1000uf 35v caps, and replaced the ones recommended ($1.59 each) only lloked like 2 had shorted, but replaced all 3 anyway
Today I recieved a monitor from a friend. It is a HP vs19e, and he said it was broken. He had...
(More)
Today I recieved a monitor from a friend. It is a HP vs19e, and he said it was broken. He had recently bought a new monitor, so he figured that I would like to fix it for myself.
Anyways, when I tested the monitor, it blinked from black to grey every few seconds when the Video cord was plugged in. It never shows the Bios or the usual " No signal"
My problem is not that of power like many others that have used this monitor.
I recently connected a new monitor to my pc. For some reason, even after the computer is off the...
(More)
I recently connected a new monitor to my pc. For some reason, even after the computer is off the monitor stays on. There are no settings that I could find related to this issue, only options pertaining to monitor power when computer is on. Ideas?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
