Question about GE Dishwashers
Water does not pump into dishwasher from line, tho
Water does not pump into dishwasher from house line, though the machine seems to engage.GE Triton XL Eterna Series model-EDW4000GOCC
The start buttom lights geen for 7 times , may be from the lack of water , but the water supply was solved & the dishwasher didnt start again !!!
Posted on Feb 01, 2010
My GE Triton XL is not working. When you push start the "sensing" and "washing" lights come on, and it fills with water. The element heats the water, but then the cycle seems to end. ...
Hi Michael,
It seems one of the components aren't doing its part in continuing the cycle. Does your machine physically pump out water?
Please confirm for me, then I will reply.
Regards
JEDEMEYER1
Jul 25, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
GE Triton 24
Hi
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please post back for any further assistance.
Daniel
Jul 23, 2010 | GE Dishwashers
My GE triton dishwasher has water standing in the
The GE GSD5500 has a check valve in the rear of the unit under the FILTER FRAME that screws in. GE part WD24X10018.
The white rubber stopper wears out and lets water return to the tub!
Remove filter frame (4 screws) and unscrew the check valve to replace. Try appliancepartspros.com for part # AP2617344.
Nov 30, 2009 | GE Dishwashers
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Dishwasher leaking water in the bottom water pump
If it seems to be the water pump, it may be the hose, unless the pump cracked. You will have to pull the machine out, run a cycle and observe to see where the water is leaking from. If the pump housing is cracked you will need a new pump, but if it is only the hose, go to the hardware store and get an appropriate repalcement hose and a new clamp, if you do it yourself, otherwise call the repairman.
Mar 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishes not getting clean in GE Triton XL Dishwasher
HI
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Oct 12, 2008 | Dishwashers
Triton XL GE Profile Dishwasher does not wash dishes well, but in particular, leaves a cloudy film.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap Aclog in the drain line or air gap (if there is one) is the usual reasonthat a dishwasher won't drain. Often the problem is at the point wherethe drain line attaches to the garbage disposer or household drainline. If you remove this line, you can clear any debris from the hoseor hose connection. Be sure to reattach the hose before starting thedishwasher again.
Pump Yourdishwasher pump ejects the water. The pump is usually mounted directlyto the motor, then attached to the bottom of the dishwasher. You canreach the pump from inside the dishwasher, but first you need to removethe lower rack, the spray arm, and the spray arm support.
Lookfor an impeller--a round plastic fan blade-type of device that spinsaround. This is the wash impeller, which forces the water through thespray arm. Beneath the wash impeller is the drain impeller, which issimilar in size and shape to the wash impeller. The drain impellerpushes the water toward the drain port. These components make up thepump. If any of the pump components are defective, you need to replacethem.
Drain valve and/or solenoid Manydishwashers use a drain valve with an electric solenoid. Whenelectricity flows to the solenoid, the valve opens and diverts thewater to the drain. Sometimes the solenoid, or the diverting lever,sticks and prevents the dishwasher from draining or filling properly.Try to free up the solenoid to lubricate the lever. Otherwise, you mayhave to replace the solenoid or pump assembly. With these systems, themotor always rotates in one direction. When it's energized, the drainvalve diverts the water.
Other dishwashers simply reverse thedirection of the motor to drain the dishwasher. These units don't havea drain valve. Instead, there's a drain hose connected directly to thepump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor Ifthe motor isn't turning or working, the unit won't drain. First checkto be sure you have power to the dishwasher. If not, see the section"It doesn't work at all." If the motor hums but doesn't turn, it mayneed to be replaced.
Some dishwashers are susceptible togetting stuck if you don't run them regularly. If you haven't run thedishwasher for more than a week, you may need to manually spin themotor to free it up. If the motor is defective, you need to replace it.Dishwasher motors can't be serviced.
Timer Partof what the timer does is control the motor and drain valve. If thetimer doesn't work properly, the water may not drain and you need toreplace the timer. This problem is uncommon.
As for testing water hardness, you can find these at your local plumbing store, or even the electricals where you bought the dishwasher from.
Hope that helps!
Sep 28, 2008 | Dishwashers
GE Triton Dishwasher will not drain they water after it's cycle...thoughts?
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
The machine was in your home 3 years , and used for more than that by someone else! I can tell you by the model that its at least 10 years old!
appliances more than 9 years old cost you money to run and fix! Throw it out and do not put good money into bad!
The new ones no matter how inexpensive will wash better and cost you a hell of a lot less to operate. They are so much more energy efficient today that they pay for them selves in a couple of years! With a new machine watch your water and power bill go down!!!
Other wise you need hands on service!
if you got the money do it new!
Bless You!
Sep 02, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Dishwashers Logo
203 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
