Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Brand new upright the back wall of freezer has a
Brand new upright the back wall of freezer has a light frost and my icecubes are sticking together. We've very little food in the freezer. What should I do to attempt to correct?
  • 4,793 Answers
I have filled polythene bags with paper scunched up inside.to fill any empy drawers this will stop all the cold air escaping and being replaced with warm damp air.....works for me.....
Posted on Feb 11, 2010
How does the Ignis afe550/ig Upright Freezer defrost?
I couldn't find any info on your freezer but there are 2 main ways units defrost. The first is manual defrost where you have to unplug the unit to defrost it yourself. These unit are typically chest freezers and upright freezers that have no fan and the refrigerant runs through the shelves. You can tell because frost will mainly build up on the shelves themselves. The second is self defrost. These units will have a fan in the freezer and a evaporator coil behind a wall inside the freezer. This wall is usually inside the freezer on the back wall. These units have a heater that is activated by a timer and comes on every 8 hours or so and will heat the coil for 20 to 30 minutes. This removes all the frost build up on the coil and you should never have to do anything. I hope this helps.
Feb 22, 2015 | Freezers
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer does not freez food at all. the compressor motor run but no cool air or freez! Please advise any solution
Since you say the compressor is running, you should check the evaporator coil inside the cabinet. Remove the back wall screws, and the back wall, to expose the evaporator. If its fully encased in frost, like a square block of snow, you have a defrost problem, heater, t- stat or defrost control. If frost only at the top, your fan is not running. If its bare of frost, all you see is the aluminum coil, you have a sealed system leak of refrigeratnt
Oct 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kenmore upright freezer quits working but can restart when the unit is unplugged and plugged back.
check the freezer back wall @ bottom if frosted up 1-bad heater (a-glass tube heater or cow rod. 2-bad times 3-bad defrost senor 4- bad fan motor
Aug 15, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
In OF mode-wont come on - is new
I have a similar freezer under the Kenmore brand and experienced the same problem. Try raising the temp setting to +10 degrees. Unit should then start up again.
Jul 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Small patch of ice if frost free freezer
Frost free does not mean no frost ever anywhere. It just means that there is a mechanism to defrost the evaporator on a regular basis. If there is a spot where frost is forming in the box it may just mean that a little bit of moisture that is not collected on the coil may be finding another cold spot to stick. The area where the fan blows into the cabinet is bound to be the coldest spot in the freezer therefore an ideal place to collect frost. Check the level of the unit and your door gasket to be sure the door is closing tight and true.
Jun 28, 2009 | Whirlpool 25.3 cu. ft. / 716 liter Upright...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
107 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
