Question about Brother MFC-5440CN All-In-One InkJet Printer
I replaced my ink cartidges and now it wont print with Black at all...does anyone know what I can do this printer has been nothing but trouble
  • 677 Answers
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!! That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 02, 2010
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
How to check whether the black in k cartidge is
If its defective it wouldnt print or you would get an error message. If you are having quality concerns then the print head is probably clogged. Nothing you can do except replace the cartridge because it has the print head built into it.
Oct 05, 2009 | HP DeskJet 840c InkJet Printer
Continue to get "empty" messages after replacing both ink cartidg
hi... try these steps
>unplug power adaptor and plug it back in
>try to identify whick cartridge is giving u trouble..black or colour by inserting carts one by one
>if sam ething happens..contact tech support on 800-332-4120..printer would be replaced
Feb 12, 2009 | Lexmark X2500 All-In-One Printer
For a while the black ink wasn't printing and only the color... and because I was not able to print using black ink, I stopped using printer, and now color doesn't even work It just prints blank pages....
The print head is clogged. I had the same problem with only the black ink. I tried to soak it over night and let it sit on a paper towel soaked with windex. this didnt work so I figured it was time to replace the printer as the print head was probably just as expensive as to buy a new one. So with nothing to loose I got out my trusty can of WD40 removed the print head, removed the ink cartridges from the heads, sprayed the bottom and filled the top where the ink cartidge sits and within 15 minutes the WD40 began to flow on the paper towel. After a while I cleaned out the excess WD40 and replaced the cartridges and head to the printer and it worked perfectly. Good Luck. You have nothing to loose.
Joe B
Jan 27, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Oct 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Mfc-240c reading offline and empty black
Regarding your problem: If one of the color ink cartidges is out of ink, the MFC 240C printer will not operate when you only install a black ink cartidge. It requires that all four catridges have ink available in them for it to function. When you examine a cartridge it may appear that it has a little ink in it when you get message that the cartridges needs to be replaced because a little ink remains to prevent the print head from drying out. JLHinton1@bellsouth.net
Sep 24, 2008 | Brother Multi-Function Center MFC-240C...
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
?I know there is ink in my cartidges but it wont let me print arrgggghh
hi,
even if you are printing only in black, some colours would be mixed. and the main color that is being used for this purpose is cyan. so you will have to change the cyan cartridge to get rid of this problem.
thanks and regards
agnel
Mar 12, 2008 | HP Photosmart 3310 Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
184 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
