Question about Hotpoint TDL15 Electric Dryer
My TDC30 makes a loud squealing noise when going
My Hotpoint Aquarius Tumbledryer TDC30 makes a loud squealing noise when going in one direction, then is silent when it reverses. Any ideas? Does it need a new belt or some other part?
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Hotpoint Electric Dryer Model NBXR453EVOWW squealing when turned
Replace the drum support bearing at the rear of the drum.
Posted on Jun 11, 2009
NO DRUM ACTION ON MY TDC30 BUT DO GET HEAT
When you start the dryer does it sound as if it is running but it does not tumble? Or does it make a humming noise?
If it sounds like it's running I'd check the belt first,
Humming noise and burning smell Dan indicate a bad motor or something stuck in blower wheel.
Oct 18, 2014 | Hotpoint Dryers
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came lose.....open up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Noisy when spinning
bearing gone cheaper to buy a new one
Jan 23, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wf321 when turn on all red light fleshing Problem nothing happenes.
half way through the cycle all the lights start flashing then it makes a loud noise when spinning
Jan 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint aquarius tumbledryer. The drum works but the heaters are not getting hot therefore not drying the clothes. Any ideas?
Check the thermal fuses / sensors mounted on the top exetrior of the heating chamber and also the heating element. Both accessible from the rear of the machine.
Nov 08, 2009 | Hotpoint Dryers
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint TDL15 Electric Dryer Logo
149 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
