Question about Samsung RS2556 Side by Side Refrigerator
Samsung RS2555SW I have a Samsung RS2555SW and the Freezer side is not working properly. It started blinking -4 so I reset it via the panel and then by unplugging it. Neither worked. This happen a month ago and I took everything out of both sides, unplugged it and let the entrie thing defrost. I even removed the back panel of the inside of the freezer and made sure all the ice was off the coils. That seem to work then. Now I am having the blinking -4 thing again and tried to reset, but to no avail. When I hold the door open and push the button in, the fan comes on, although it is a bit noisy when it starts, and there is no cold air coming out of the top part of the freezer. There is cold air coming out of the bottom half. Could this be a fan issue or something else? Thank you for your help.
  • 2 more comments
  • 4garbers Feb 01, 2010
    I just defrosted it a month ago. Everything started working fine and know it started again. We have had this refrigerator for 5 years and it has worked perfect until Dec. 09.
    The Refrigerator side is totally fine. There is no temp issues. Does that make a difference or would it still be a defrost problem?
  • 4garbers Feb 02, 2010
    Okay, we did a force defrost and the freezer is defrosting. I wasn't clear if you meant to use the OHM meter with the thermostat plugged in or out. Either way, out = nothing, in = 2V DC. The fan, when we pulled the inside panel off, was working fine. Does this mean thermostat or do you think adaptive defrost?
    Thank you for all your help!
  • 4garbers Feb 09, 2010
    Thank you so much for all your help!
  • 4,059 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located on the back .
Part 6 on this diagram is your defrost control.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174704&diagram_id=1346448#d1346448
Posted on Feb 01, 2010
  • 1 more comment
  • Charles T Nevin
    Charles T Nevin Feb 01, 2010
    It can be a fan issue. You said it's noisy on start up. It could be the fan itself or the fan could be hitting an ice buildup. Take the rear cover inside the freezer and you will know it it's a defrost issue or fan. When there is a defrost problem, it's a gradual thing getting a little worse every day.
  • Charles T Nevin
    Charles T Nevin Feb 02, 2010
    Since you could force a defrost that means it isn't going into defrost on it's own when it needs to so it looks like it's the module that's the problem.
  • Charles T Nevin
    The adaptive defrost control that is.
  • 15,935 Answers
Is the evaporator fan working properly... and the evap coils free of ice?
You may have a defrost timer issue.
Thanks
2 Suggested Answers
  • 41 Answers
SOURCE: I have a Samsung RS2555SW and the Freezer side is
Sounds very likely it is the fan , it cud be the fan is hitting some cable or ice as well , or the fan motor has had it , most of those fans r 240 volts , so any fit any
Samsung fridge RS2555SW is not working. all temp lights are blinking. can you help
May be it needs reset. Unplug the unit for 12 hours and then reconnect to see if that makes any difference.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Samsung Refrigerators
Refrigerator malfunction
samsung units have duel cooling. that means there is a evaporator in the freezer and the fresh food section. it is possible that the temp sensor in the refrigerator section could be bad. and they have been known to have defrost problems there to. the samsung is a complicated unit and its hard to describe how to repair since there is a lot of electronics that control everything. the best thing I could say is to unplug the refrigerator for a few minuets. sometimes this will reset everything and start the unit back to the factory settings. if that does not work I would call for service. hope it helped you some
Aug 04, 2007 | Samsung RS2556 Side by Side Refrigerator
Samsung RS2555SW - Refrigerator or Freezer is not cooling. I have removing the access panel inside the freezer. There coils have zero ice on them. The fan that is there does not seem to turn on. I have...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 .
Oct 20, 2010 | Samsung RS2556 Side by Side Refrigerator
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
I have a Samsung RS2555SW and the Freezer side is not working properly. It started blinking -4 so I reset it via the panel and then by unplugging it. Neither worked. This happen a month ago and I took...
Feb 01, 2010 | Samsung RS2556 Side by Side Refrigerator
Bot the fridge & freezer have quit chilling..
sounds like something pocked a hole in the refrigerant line ether inside or out side leak needs to be found and repaired with epoxy and coolant refilled
Oct 28, 2009 | Samsung Refrigerators
THe freezer is working fine, but the fridge is not cooling very well MODEL HTS22GBPBRWW
samsung RS2555SW the freezer temperature is 58 tryied to changed to -4 it goes back to 58
Aug 13, 2009 | Hotpoint Refrigerators
Dash light on monitor no refrigerator temperatures shown on monitor how to reset
Hi there, I have the same problem with my samsung side by side the model no is- RSA 1Wtmh .
The light started blinking after a power cut and the elec came back on and the fridge light just blinks on panel instead of showing temp (the fridge and freezer are working)?
Jul 14, 2009 | Samsung Refrigerators
Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
Jan 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Freezer defrost all. RS2556
The most likely is that the door was not closed properly, this is very common on this model, what happens is that the door closes against the freezer contens and therefore appears closed, this allows warm air into the unit which starts to melt the ice, if this should happen again it is a good idea to completely defrost overnight with the doors open and then re start the next morning as ice often builds up behind the rear panel. Regards Advisor
Jul 04, 2007 | Samsung RS2556 Side by Side Refrigerator
Samsung RS2556 Side by Side Refrigerator Logo
254 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
