Question about SanDisk Sansa Clip MP3 Player
I hv sansa clip 1gb - in which i have some songs i.e aprox.850mb and that cannot be seen in my pc in sansa clip as a drive g.how to delete songs and add songs , is there any driver of software or programme?
  • 63 Answers
1. First, check your device setting up on MTP or MSC? Turn on device, go to "settings" , press down or up to find "USB Mode", you can see the check mark at MTP (auto detect) or MSC mode. Change to another usb mode.
2. You have 2 ways to delete songs:
2.1. Delete songs by device: play songs, press down (sub menu) until you meet "delete song", select it and yes
If you delete all items in device: Settings, Format, and yes
2.2. Delete songs by computer: plug device to computer, double click on device icon, Music folder, and delete songs you want. If you don't see songs in there, unplug the device from pc, and then change USB mode, and plug device to pc to delete.
Good luck
Posted on Feb 02, 2010
I have down loaded a bea to delete other songs -also I have one auto book I am not able to delete
What is a 'bea?'
One way to delete songs (and maybe books) easily is to it through your computer, while the Sansa is tethered;
1) Download the Sansa Clip manual. Here's a link;
http://www.sandisk.com/media/327475/CLIP+_UM_0809_ENG+090309.pdf
2) Put your Sansa in MSC (Mass Storage Class) mode.
Go to Settings, then USB Mode. Select MSC mode.
3) Tether the Sansa to your computer. It will look like a USB flash drive.
4) Delete or add Music, or Books.
You can use Windows Explorer to look through the directories on the Sansa, and delete files directly, as you would on a USB Flash drive.
Special Note on Audio Books--
Get an extra memory card, 4 to 8 Gb should do, and use this as your destination for audio books. If you have a book that will not delete, you can pull the card and re-format it, while leaving your songs intact on the main memory.
If you cannot delete the book through the computer or by menus on the Sansa, you may have to re-format your main memory. Hope that helps!
Nov 17, 2011 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't work. When I turn it on it says: Not enough space for music DB Please free 30 MB. But when i connect it to my computer it doesn't register. PLEASE HELP ME
Because you drag 7 drop songs or files too much into the sansa clip in MSC mode, it causes like that.
Turn it on, it will show " Not enough.....free 30 MB", and then automatically turn off. Plug it into pc, open my computer, it will be under name "Sansa clip..." or "removable disk ". If your pc does not recognize it, unplug again and replug it.
Open Sansa Clip..., or removable disk, and delete some songs.
Good luck
Apr 30, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip 2GB MP3 player won't let me add any more songs to it, even though there's 1.26 GB still available. I don't want to reformat the player, cuz that'll delete the songs I already have on there. ...
Hi there..
When you say having difficulty in adding the songs in CLIP, though you have enough space. I'd kindly request you to check for the number of songs that you have added.
Because when you add as MP3 player by default its bit rate is 128kbps so you can add up to 500 songs only. Kindly have a check on it.
I have given the number of songs that can be added with related to size of MP3 player..
Size of the player :512MB 1GB 2GB 4GB 8GB 16GB 32GB
Number of songs : 125 250 500 1000 2000 4000 8000
Kindly revert if any clarifications....
Jan 30, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip+ 4 GB mp3 player. How do you delete
Select the song/book (you want to delete) to play, press down button (Music Options), and press all the way down until you meet delete song/book, press delete song, select yes.
Good luck
Jan 21, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Clip keeps deleting itself
1. Format your device (save songs before do it).
2. Update new firmware http://forums.sandisk.com/sansa/
3. Resync songs.
Good luck
Nov 04, 2009 | SanDisk Sansa Clip MP3 Player
I just got a sansa clip 1gb mp3 player & need help on everything!
The Sansa Clip is not compatible with iTunes. You will have to get your music from another music service, preferably one that gives you the songs in mp3 format instead of AAC format (although it will accept WMA's, the DRM-protection system on most WMA's will give you problems down the line, especially if you cancel the music service that you got them from - songs in mp3 format will be usable even after you've cancelled your music service subscription).
-Tha Mp3 Doctor
Mar 03, 2009 | SanDisk Sansa Clip MP3 Player
SANSA CLIP MP3
There are two ways to delete files on your Sansa player.  You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device
1. In playback mode, press the Submenu button.
2. Select Delete
METHOD 2 - Delete files using a PC
1. Connect your device to the PC.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your files are stored.
4. Click to select the files you want deleted and delete the files.
NOTE: If songs still exist after deleting, you may need to switch USB modes from MTP to MSC or vice versa. Seeanswer ID 447 for more details.
Rock....!!!
Feb 19, 2009 | SanDisk Sansa Clip MP3 Player
"No Song" displayed even though music has been loaded, many times
The songs ripped from CD are not in the right format. In Windows Media Player, highlight the Rip tab, click the black arrow under the Rip tab, select Rip Options --> Format --> Mp3. Now, re-rip the songs. Before you transfer these tracks to the player, make sure you delete the tracks that are on the mp3 player now, or else Windows Media Player wil ltell you that the tracks are already there. Now, transfer the newly-ripped Mp3 tracks to your Sansa. Should be good to go.
-Tha Mp3 Doctor
Jan 10, 2009 | SanDisk Sansa Clip MP3 Player
Somehow i deleted everything!
There are a few different ways to delete songs off your player - see especially the method involving the firmware update.
Preventive Medicine: To prevent Windows Media Player from adding all of your My Documents files to the Sansa player every time you connect the Sansa to the computer - Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Set up Sync". When a window pops up, uncheck the box that says "Sync device automatically".
Quick Method 1 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Quick Method 2 - Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Slow Method, allows more control over what gets deleted: In Windows Media Player 11, the files are organized by Music, Pictures, Videos, Etc. First, you will want to plug the Sansa player into the computer. Then click the Library tab in Windows Media Player. You will most likely be in Music view. You will see two sets of folders in the left-hand side of Windows Media Player. The first set are all the files stored in your computer. The second set of folders underneath the line that says Sansa 1GB Mp3 player (I forget the exact wording) has all the files that are stored in your Sansa player. Click on the "All Songs" folder. You can individually delete all the songs that you want by left-clicking once on the song name in the middle of the Windows Media Player window, and then pressing "Delete" on your computer's keyboard. You will have to repeat this process again for images, videos, etc by clicking the little arrow next to the picture of the musical note on the upper left hand corner of Windows Media Player, and expanding the dropdown menu, and selecting "images"...then "Videos" etc.
NOTE: After plugging in your Sansa player, if you see a message that says "Connect a Device" in the Sync tab on Windows Media Player, then the cmputer is not properly recognizing your Sansa player, and you may need additional instructions from me.
-Tha Mp3 Doctor
Mar 15, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
207 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
