Question about U-Line Icemaker
Need parts thermostat, ice maker bin, pin for
Need parts thermostat, ice maker bin, pin for door.U LINE Model combo 75
  • 93 Answers
U-Line PH # 800-779-2547
Posted on Mar 03, 2010
Too much ice in binn
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Ice Maker Is Frozen Up This ice maker repair is even easier. If your ice maker has frozen up, take the following steps to thaw it out:
1Unplug the refrigerator.Remove the ice bin from the refrigerator and remove any loose ice from the ice maker.
2Find the fill tube.This is awhite rubber-like hose that delivers water to the ice maker. Pull down the small metal clip off the housing that holds the fill tube (though not all ice makers have this clip).
3Warm the hoseand surrounding mechanism. To do this, you can train a hair dryer on the ice maker to melt any ice blocking the mechanism. But be very careful (sop up any dripping water with a rag) as electricity and water can present a serious risk of electrical shock. Also, be careful not to melt the plastic parts.
4If you don't want to use a hair dryer,you can soak the supply tubing with hot water, using a turkey baster and catching the overflow in the empty ice maker bin. In some cases, it may be easier to remove the ice maker than to thaw out the fill tube.
On heat release ice makers You will want to check the heating element within the ice maker for continuity and a visual inspection of the board and conductors for burns and seizing, chared marks.
How to Test the Ice Mold Heater There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver. Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. It is easier to work on this type of unit by first removing the entireicemakerfrom the freezer compartment. The unit is usually mounted to the freezer case by two or more screws. Remove the bottom screws first. While supporting the ice maker, remove the remaining top screws. Unplug the ice maker from the freezer cabinet if you have not already done so. Along the edge nearest the shutoff arm, a pin protrudes through the mounting plate . The arm pin has a spring under the mounting plate. Reduce the tension on the spring by moving the shutoff arm into the "on" position, down, against the ice maker.
Test the heater for resistance using amultitester. Set the multitester to the ohms setting X1. Touch one probe to each of the two terminals (or wires). The reading should be in the range of 60 to 90 ohms. If you get a significantly different reading, such as zero or infinity, then the mold heater is bad and needs to be replaced. Conduct this test with the refrigerator unplugged. Test the moldheaterfor resistance using amultitester. Set the multitester to the ohms setting X1. Place one probe into the hole labeled "H" and the other probe into the hole labeled "L". The multitester should read in the range of 60 to 90 ohms.
Also be sure to check and test water valve with a meter for continuity and voltage..( a full 120 and nothing less) And a visual inspection for any ice build up or blockage in tubing and flow line. Remember u may get a close circuit reading of continuity however it may still be bad in that it may remain constantly closed and water keeps flowing more than suppose to. Hence chunks of ice build up.
Jun 20, 2014 | Samsung RS2578BB Side by Side Refrigerator
Water leak behind ice bin
likely so unless you can get the seal ring. However, it first needs to be determined which part causes the leak as they can be many sources
Dec 10, 2017 | LG LFX25971ST Bottom Freezer French Door...
Lfx25978st ice tray stuck
This sounds like a thermostat in the ice maker has failed. Unfortunately, LG provides no replacement parts for the ice maker. They say to just replace the assembly, so there is no alternative other than ice maker replacement. Here is the ice maker to order.
Nov 27, 2012 | LG LFX25978ST 24.9 Cu. Ft. French Door...
I have a Maytag MFI2568AEW refrig. and the ice maker is not filling up. I checked the dual water valve and it is not getting power to open the solenoid valve with the ice maker switch on and the ice bin...
On typical ice makers that signal comes from within the ice maker. It sends a signal from the ice makers thermostat and the ice maker begins to pre-heat the ice cube slots and the ice rake begins turning to push the ice out of the slot's and into the ice bin. The last function is to refill the water with a signal to the dual water control valve that last about 7.5 seconds. Once the ice maker senses the water is frozen again it begins this cycle again. Here is a refrigerator parts PDF for your model=> MFI2568AEW and on page 10 you will see part=> 627985 Pin Style Icemaker Thermostat
Adhesive - Alumilastic (Cement)
That is just silicone rubber you can also get locally. If you have any other questions please let me know, Thanks, Sea Breeze
Y13068002 or Repair Clinic 1266731 Ice Maker Assembly
Feb 17, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Ice maker not making ice
To check ice makers in general you have to first check there is water which is simply filling a glass from the freezer door dispenser. Next you need to check there is not a frozen fill tube where the water is run through the cabinet into the ice maker.(you should be able to blow through it from the back when you disconnect the line) If it has frozen solid with water, this has to be cleaned of the ice(melted with a hair dryer) Frozen fill tube problem usually caused by water valve not completely shutting off-a drip) May work ok with old valve for a while without replacing also.
The next is to test water valve and ice maker by jumping the thermostat inside the icemaker assembly, there are pins under the cover of the ice maker. If you are this far also check for 120 volts at ice maker. This is general, if you have a ice bin in the door, you have a emitter receiver board which needs to be jumped out. It can get complicated, but you are trying to break down the system components to isolate the problem.
Also remember ice makers generally have a thermostat in them to prevent operation if not down in the zero to fifteen degree range. You can get one of those outdoor liquid filled mercury or alcohol stemmed thermometers to test your freezer temperature before you tear apart your fridge..........
Jan 19, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice in front of bucket freezes together to form block of ice . Unit is a Combo 75 FB
if unit is not level the ice maker will over flow causing the cubes to ( what looks like melt to gether . ck the door th make sure it's sealing . any of these could cause the problem . ice mker may be bad causng valve to stay open to long causing over fill . ****
Jan 04, 2010 | U-Line Icemaker
U-line combo not making ice. Have cleaned
bad water valve, thermostat, freezer not cold enough, make sure the ice maker metal rod is at down position or on back of the ice maker plastic water line is frozen. also depends what year combo you have, there operation is a little different.
Nov 15, 2009 | U-Line Refrigerator Ice Maker
My u line under counter ice maker (bin, not clear ice) will take forever to make ice. Once it starts to make ice and drop it in the bin, several hours later it will stop making ice and the made ice will...
Can you tell me the model? If its a bi series then it should make ice every 45 min. temps should be 10-15 degrees in bucket. If its a combo then it could take 24 hours to make 1/2 of the bucket.Should be the same temp in your bucket.Make sure you dont have heavy frost in the freezer, Make sure the condenser fan is running and clean.If the temperature in freezer is alot warmer than this and everythng is running then it could be a leak in the system. If its colder than that then set the thermostat to a warmer temperature
Aug 06, 2009 | U-Line Icemaker
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
U-Line Icemaker Logo
131 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
