Question about Dishwashers
I have a Kitchenaid dishwasher. Mod # KUD102CRBS1 which is hardly 2 years old. The door keeps separating from the trim and water seeps out, I fastened the trim, this took care of the problem for ca 6 month, now it is leaking again from the door, has anyone the same problem? I am steaming mad, this was an expensive appliance, which could only clean dishes somewhat with one brand of detergent, all other brands leave a gray film, and now this! MY previous dishwasher was a rel. basic GE but it got the job done and I had it for 10 years without problems. Have there been recalls
  • 12,061 Answers
This is a fairly common one... I always use a silicone sealant/adhesive to make sure it stays put. A thin film does wonders.
Posted on Feb 01, 2010
Rusty water dripping on the inside of the door after rinse cycle
Pull the screws out of the door check to see if they are rusted run the machine the outer door panel off should be easier to find the leak
Mar 30, 2014 | KitchenAid Dishwashers
Is it worth fixing a 10 year old KitchenAid Superba side by side?
Pull it out... - turn OFF the water inlet valve..
........... if it still keeps everything cold,,, keep it,,
Jul 08, 2017 | KitchenAid Kitchen Aid Superba Series...
I have a kitchenaid quiet scrub dishwasher that fails to function. When you close the door and press the start button the clean and cancel lights come on and the pump starts up. No water enters the...
ther is a small impulse pump on the bottom of the unit. the diaphram gets old and it stops functioning but sometime then it leaks . so if it's not leaking , turn off water suppl and remove the fitting for incoming water some have screens right here and they get plugged with hard water debris . ha dont be silly all water is dirty.you can get new screens at h/d and lowes, hope your solenoid still works, check it by putting a finger on it when the cycle should start it should humm or vibrate. diaphram is not replaceable. need to buy new valve
Sep 06, 2012 | KitchenAid Dishwashers
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
GE Side by Side Refrigerator seeping water onto door
Hey, thanks for the photos. Have seen this problem before. Seal the recess area, at the front edge and the front corners, with a little clear silicone, to prevent water from getting behind the stainless steel door panel. I've heard people say to seal the rectangular holes along the bottom side of the door panel recess cut out also, but that shouldn't be necessary, as if you still had water behind the panel, it would just then seep down behind the SS door panel and continue to cause problems. The real cure is to keep water from getting in there in the first place.
May 03, 2009 | GE GSS25QSTSS Stainless Steel
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Dishwasher does not clean dishes and leaves spots on everything!!
You need 2 things. Slightly hotter water and a rinse agent. If you don't heat dry your dishes, crack the door 3 or 4 inches after it's done, to let the steam out.
Mar 04, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
KITCHENAID dishwasher will not dry the dishes
kitchen aid mod kud101dl does not clean dishes well. lot of scum on door.
Feb 26, 2009 | KitchenAid Dishwashers
Milky liquid residue on washed dishes
This sounds like hard water spots.  Use Jet Dri or a similar product to reduce it. Use the recommended amount of detergent.
Nov 15, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwashers Logo
282 people viewed this question
Top Dishwashers Experts
